Jman841
I never have to turn the volume any louder than 11 o'clock. For the majority of music and videos 9-10 o'clock is loud enough. This applies to all my headphones.
What is the Amp? the K5 Pro has 3 gain settings.
I recommend using MathEQ if you’re using Foobar2000.So I found the measurements someone took and used them to add some EQ. These roll off very heavily in the treble after the 4k peak, For EQ, I added a bass shelf at 166 hz of 3 db, added 6 db at 9k with a Q of 1 and added 5 DB at 16k with a Q of 1.41. Pre-Amp set at -6 db to prevent clipping.
I am no means a pro at EQ, but wow, it really brought out a lot more detail and balance, especially to Tool. The cymbal hits are very crisp and clear now where they were faded to the back before.
Does it have a sine wave sweep generator? I'm familiar with EqualizerAPO and Peace EQ is a GUI add-on of EQAPO right?I'm using Peace EQ
Nice. So how does the sine wave sound now after your EQ?Yes to both, it's the GUI for EqualizerAPO and allows you to run a frequency sweet in the "Test" section.
Sometimes my ears touch, I used to have this problem when I first started wearing them but now I’ve found the most comfortable position for my ears.Does anyone else's ears touch the drivers? At first I didn't notice it much but now that I wear them more it's getting a sore spot on the outside of my ear where it touches.
I know metal is all the coolness with "premium" headphones, but I would be much happier if these drivers were in an HD 5X0 style headphone. Those are so light and comfortable I can wear them all day without thinking about it.
