Writing some comparisons among ATH-M70x, Audeze LCD-1 and Hi-X55 before my memory fades out. I don't have LCD-1 and Hi-X55 at the moment.
I'm not a professional or audiophile, playing around headphones is just a hobby so assessment might not be accurate.
used SoundBlasterX G6 for the source.
Build
1. Hi-X55 - metal headband, pleather pads, replaceable headpads. this design reminds me of AKG K553 + K371 + Shure 1540.
2. M70x - all plastic, metal headband inside of the plastic, pleather pads
3. LCD-1 - all plastic, metal headband inside of the plastic, genuine leather pads, it makes squeaky noise when moving jaw
Comfort (I use Dekoni nuggets for all headphones, can't stand heat on the top)
1. M70x - little heavier than LCD1, sometimes ears are touching the driver, clamping force and dekoni nuggets placement (on the plastic) was perfect.
2. LCD-1 - little more clamping force than M70x, smaller ear pads. dekoni nugget placement is in between extended metal frame and the plastic parts (kinda odd)
3. Hi-X55 - pads are comfortable, but over 300g is a bit heavy for long listening session. had to take a break or keep adjusting position after couple of hours. placed the dekoni nuggets on the plastic parts on the sides
Sound Isolation
1. Hi-X55 - very strong, sometimes feel like flying on high altitude, don't feel good when take off the headphone though (feel like air sucked out from ears)
2. M70x - inside of pads are fabric, so sounds goes out from the earpads ,but blocked by the plastic earcup, feels comfortable. not as much suction/isolation as Hi-X55
3. LCD-1 - yeah, open back
Soundstage
1. Hi-X55 - instruments are further away
2. LCD-1 - feels like semi open, quite small as opened back
3. M70x - smallest, but not right on your face like M50x, I think the fabric inner pads helped the little bit bigger
High
1. Hi-X55 - very high resolution, sometimes harsh with resonant combination with strong isolation
2. M70x - high resolution, sometimes harsh, but less than Hi-x55 because of the hybrid pads (doesn't much resonant)
3. LCD-1 - relaxed high
Mid (doesn't much remember)
1. LCD-1 - forwarded mid? (probably bc it has relaxed high)
2. M70x - less energetic
3. Hi-X55 - felt some resonant combination with strong isolation
Low
1. LCD-1 - fast cleaner/tighter, more energy (it's bass light compare to other headphones like M50x, but among them i think LCD 1 got better as planar)
2. Hi-X55 - fast clean/tight, but lighter than LCD-1 (feels a bit further away), hearing double kicks clearly. sometimes feel like blanket in the bass drum
3. M70x - little more rumble, but bit slow compare to other two
there are pros and cons on these three headphones, and I like all of them, especially Hi-X55 and looking forward to get a pair when it becomes lower price on eBay.
