0o0o0o
- Aug 16, 2010
Will be getting these very soon as they just cleared customs. Who requested a comparison with a UM TF18 (TF10 upgraded to 6 drivers)?
Why I did sir.
![ph34r.gif](http://files.head-fi.org/images/smilies/ph34r.gif)
What flimsy little audiologist box are you speaking of ? Surely not the Otterbox case Aurisonics ships in, that thing is built stronger than a tank.
Some pics of how things are coming along. So I'm painting the right piece black/red, and wanted to paint the left piece white/blue, but I'm having a hell of a time getting the white to go on evenly. I may have to resort to spray painting the face plate, or just painting it black as well. It's nice and shiny now with the polyurethane coating on it. Can't wait til it's all dried up![]()
The new round shaped Compy TS500 tips came in today. I usually don't like Comply at all, but these are perfect for the ASG-1 (unless you're going to get custom tips). Great isolation and I feel like I'm in a room designed for an audiophile system. Comfort is sublime!!
Hey thanks guy. I'm really pleased with how well it turned out. The right side turned out exactly how I envisioned it. I may end up painting the left side black after all. I got the blue/red, left/right idea from my SM3s, which contain bits of blue and red rubber on the crossovers (?) that are visible through the transparent plastic. As for the black/white thing, that was from staring at my Wii and PS3, the PS3 is piano black with a red LED, and the Wii is a glossy white with an illuminated blue disc slot, so I thought those were really cool color combos that I wanted to emulate. As for the paint I used, it's nail polish believe it or not. I decided against acrylic paint simply because it wouldn't be as easy to apply, and with nail polish, I could use a bit of acetone on a fine brush to remove any mistakes I made. I'm going to seal it with two coats of polyurethane, which should hold it pretty well considering it's the same stuff that protects my hardwood floors and the wood trim around my house.
Eric, you prefer the Round Comply tips or double flange tips, I checked out the TS500 too but wanted to wait a bit for impression because the tips are not cheap
