codster303
- May 5, 2014
Although I had hoped to be posting my initial impressions today, but I've yet to play anything though the X1.
Onto the problem, after I plugged the X1 in the USB 2.0 port a window pops up saying its installing device. After it closes I go change my default audio output and find that its not listed as an audio device. When i look at devices and printers its shown as "SA9027 USB Audio" in a separate "unspecified" category. If I look in the device manager it's listed an "USB Component Device" and has a yellow exclamation point. In the device status it says "This device cannot start. (Code 10) STATUS_DEVICE_DATA_ERROR".
If I plug the X1 Into a USB 3.0 port windows fails to recognize the device. Although I've read that some USB DACs will not work with certain USB 3.0 cards and hubs but that is not a major problem.
Here's the equipment I'm using:
Acer Aspire V3-771G-9441 (specs on amazon)
Windows 8.1
foobar2000
ATH-M50
and of course the Aune X1 Pro with the cables and power supply that came with it.
What I've done so far:
I've uninstalled the driver many times, restarted the computer several times, deleting the lower and upper filters.
None of this has helped; it still does the exact same thing.
As far as I can tell the X1 is working properly the lights come up I can change inputs, the amp works by itself using line in from my the computer. There is slight static when i turn the volume to very high levels, but i don't see that being a big problem right now.
Windows 8.1
foobar2000
ATH-M50
