Yes. You can absolutely use the DAC with a different, lower impedance amp.
Alrighty
![Headphone Smile :) :)](https://cdn.head-fi.org/e/headfi/smily_headphones1.gif)
. I didn't know which device had the impedance issue, but I assumed it was all devices.... Someone was talking about impedance via cables, so I figured that there could be issues with connections causing problems and whatnot, and maybe certain more expensive cables were better impedance, which is why they are more expensive, and why some users don't notice "a difference?"
So an AMP will have the impedance... not the DAC?
I wanted to originally hook it up to my Sound Blaster, but then I realized there is no damn line outs, and a bunch of line ins....
So I guess it doesn't matter since the amp/dac are going to be on it's own, so I guess I could get the Aune then?
The question is... Would it be worth it? I don't know anything about Tubes, but from the talks here they sound amazing...
I am getting the Fidelio X2's, so not sure if the tubes would be too "warm?" I heard once there are bright and warm tube amps, and you need to pick the right one...; however I saw a video which was basically talking down tubes, and they were saying they were just warm... Granted these 2 guys don't really seem that knowledgeable, and if they are(or the one audio guy), they don't really present good arguments...
They spoke about "Coloring" the music, but that sounds like some audiophile purity ****, which they constantly try to talk down "purist/elitist Audiophiles" while being elitist themselves.....
So the questions are....
1. Should I get this DAC for the X2's, or should I look somewhere else? I find this is a cheap intro to tubes, but I'm new to all this gear in general, so I'm not sure if this is the best start, or what, but it sounds great!
2. If I got this DAC....
a. What kind of amp should I get for the X2?
b. Would it be okay to get an SS amp for it, or should I get another Tube Amp? It seems the Aune is unique, because it's a "Tube DAC," but not sure if it needs a tube amp with it or what the "preferred setup"wold be... Would a tube amp and a SS DAC be better...?
c. I hear the Aune gets very hot.... Should I setup some sort of fan for it, or should I put some vents into the case?
d. I see there is a 96 and a 192khz Aune, but people say there is only the 96... I also saw in that video that they were saying there is no audible difference between the 2, which I'm not too sure about....
e. I've seen people change the capacitors and such on this... It is worth it to mess around? One thread I saw mentioned he fried 2-3 of these before getting it right....
f. What kind of tubes should I get? I really am interested in one of those Amperex 7803's, but I hear mixed opinions on these tubes....
One person said that the grade doesn't matter, while another said the grade will matter with I believe "Microphonics," so getting a higher grade is always worth it?
I also was looking at Upstart, and the 2nd user seemed to dislike them due to higher prices, but they seem to know what they are talking about. With that, Upstart claims that all of the Amperex are the same, while user #2 claimed that the label is what matters... I'll have to check out what the comments were, but it was a fewe pages back I guess (not sure if you were the one I spoke to
![Stick Out Tongue :p :p](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
The Gold Lion and the Bungle/Rocket Boy sounded good too...
I guess it depends on my music, and what I like.
I like music that is more fun, engaging, energetic, exciting, and makes you want to move.
"Eurobeat" is big in the car/racing scene in Japan, so it's a lot of FAST Adrenaline pumping music!
