Koolpep
Hi there,
I'm Scott, and I am new to all of this equipment, and admittedly a bit lost (although excited about where I will likely end up once I get this all figured out).
So, I bought my first piece of equipment in search of seeing just how good music can sound. Specifically, I picked up the Aune T1 MkII and it arrived today. Like a kid, I just had to play with this new equipment right away and am concerned that the unit I received is defective somehow. I'll do my best to explain the issues I've noticed.
I know that the unit requires about 50 hours of running time before it will sound like it should, and assume that is why it generally sounds a bit muddy out of the box (especially in the middle frequencies - I really hope I'm not making a fool of myself trying to explain this, haha). On the positive side, I've already listened to several tracks and have heard things in these songs that I never knew existed in the background. To say that I am intrigued & excited about the possibilities of this unit would be an understatement. The reason I am concerned that the unit I have is defective somehow has to do with the gain settings. As others have mentioned, the unit arrived with everything switched to the ON setting. I switched everything off as a starting point and was shocked at how awful the thing sounded. So, it was on to fiddling. This is what I've found:
If I move both "1" switches to on, the vocals almost completely disappear.
If I only move the "1" switch closest to the end with the headphone jack, the vocals come back and the unit sounds much better (although the vocals still do not match the sound I previously got by going through the headphone jack in the computer itself).
If I switch on both "2" switches, it gets a bit louder, and neither improves, nor detracts from the music much. I currently have these off as the sound seems slightly better with them off vocally.
The only other observations I've made are that it sounds best with the Foobar2000 music player (which I read about here) and I only need turn the volume 1/4 of the way up to get a volume which I enjoy (vocals seem almost normal with this player). When I use my VLC or Windows Media Player to watch a concert DVD (or any other video) I need to turn the volume up to the 12 o'clock position to get the same volume.
I don't know if computer hardware is important, but what I am working with is a Windows 7 PC. I initially had a very digitized sound coming out of the unit, but reading up on the USB connections, I was able to adjust the settings and made sure to get it in to a solo slot and that problem went away.
So, any thoughts? Is there something wrong with my unit, or is this normal?
Once I get this figured out, it's on to headphone recommendations. I was thinking of the Mad Dog Pro, anyone know how well those pair with the Aune?
The gain switch is per channel. Each DIP switch box is for left or right.
So I just tried it on mine and no, vocals do not disappear, it purely affects the volume/gain comping out of your headphones. Check your headphone connectors. But it is important that both switches are in the same position. So either all off, both 1 on 2off or both on.
If music sounds in any way distorted, or as you said: digitized. Something is weird. Do you have another PC you can try it on?
Since the T1 is a pretty powerful amp leaving them on zero gain is in my opinion the best idea. Which headphones are you using with the T1? If you don't have any high impedance headphones, no gain is needed.
Cheers,
K
