MrEleventy
- Oct 24, 2012
Coil: Look for ClieOS's portable amp shoot out. He has one for $ >100. cMoy and pa2v2 I think is up there.
Gaming is going to suffer using an external dac, unless it's designed for gaming. Most dacs are stereo so you'll lose out on the positional cues from the 5.1 that the internal cards + software will process for you. You might be able to downmix to a PCM stereo output in game but I'm not sure if it'll work or even be effective enough. You might want to look into a mixamp or a Asus Xonar U3 for gaming.
What warm sounding amp would you guys suggested within O2amp price? My Aune T1 + HD 600 can be to bright sometime and I read that the amp is the culprit. Thinking of changing to warmer one. Crack definitely out of my league.![]()
Fiio E09/k would work. M stage if you find a used one can be had for around 150. And the o2 might be dark enough when compared to the t1s amp.
Why not just look for a warmer tube?
Amperex 7308 would be the upgrade of their 6dj8, maybe that might work. Or look for a Brimar or Mullard. They tend to be on the warm side.Is there a tube that brings out vocals more than the 6dj8 orange globe?
Give the Amperex Orange Globe 6DJ8 a try, should be about $10-20 shipped on ebay. Probably the cheapest solution.I see... Thanks. Will look for O2 to borrow for testing purpose...
Tube will really affect the sound? Tube aren't that expensive right? Well, if tube can change the sound to less bright, why not. What tube you recommend then sir?
I don't think it will. The m100s are pretty sensitive and efficient, I don't think amping will help or hurt it. I don't notice any difference when I amp/not amp my m-80s and the T1 didn't make the highs sound better which I was looking for. V-modas are pretty, "What you hear is what you get" with their tuning. It's a DJ type can so warm and smooth highs are where it excels on.well in all honesty when I game with my audio technica ath ad700's I typically have my soundcard set to the "entertainment stereo mode".. my soundcard does have a gaming mode with some type of software that does 5.1 but it doesn't necessarily help. I'm more concerned with best possible music quality. I'm just wondering how it could possibly make my vmoda m100s sound better
Only thing I can find that fits is this LINKI have some spare tubes of the 12AU7 "family"/series...As someone answered me before,these unfortunately are not compatible with Aune T1...
So my question is: Is there any similar product (tube dac+HP amplifier) ,in the same price range,which is compatible with 12AU7 tubes?
Thanks!
E:
The differences in rolling the tubedac are kinda subtle, the tube amp will amplify those changes and from there, I can fine tune it a bit. The Amperex Orange Globe pushes the mids forward but rolls off the treble and bass, I have a pair of tubes in the DV336 that enhances that so it balances out. And at times, I'll roll in the TFK PCC189 which flattens out everything so it's neutral and all I get is the benefits of the DV336. It's hardware EQing basically that's system wide.I noticed you're going tube DAC to tube amp - what is the effect of "doubling up" on tubes in this way?
Oh, boo.Thanks!
I'll contact the seller..(it seems it has tube amp section instead of the ss of the T1)
