Feb 15, 2014 at 8:22 PM Thread Starter Post #1 of 6
Charliemotta
Port Richey, Florida
When I use a 12AX7 or 12AU7 tube in my AuneT1, it sounds terrible. I usually have the volume right at 12 o'clock with any other tube (6DJ8 or 6922EH). Now with the 12's I have to turn it up all the way and I can just start to hear it and it's sort of muffled. This 1st happened with a 12AU7 and I sent it back for a 12AX7 and the same results. What am I missing here.
Feb 15, 2014 at 10:14 PM Post #2 of 6
here is list of all compatible tubes that should work with Aune T1 ,please refer to this list next time you purchase your tube
http://www.head-fi.org/t/633006/aune-t1-usb-tube-dac-amp-discussion-thread-see-first-post-for-faq/4200#post_10162534
EDIT; you will need socket adapter....9pin 12AU7 style
Feb 24, 2014 at 5:27 AM Post #6 of 6
Even with the dip switches on the bottom of the Aune T1 set to full gain you still have to crank it that high with the 12's?? wow :(
-Jamie M.
