Aune M1P
Dec 11, 2023 at 4:43 PM Post #211 of 593
This thing throws me back into early 2010s. OG Aune M1 had awesome SQ, didn't want to read half sd cards out there, supported only .wav and had the worst possible UI. I borrowed it for a day, but couldn't live with it.
I might just get this one mostly because bluetooth. How is receiving quality here? And no LDAC, just aptx hd?
And does it support any type of quick charge? 6 hours is ok if I can charge it to 80% under 30 minutes.
yeah charging is pretty quick. not sure if that fast but not slow. next time i'm down i'll charge it and let you know
Dec 12, 2023 at 3:53 PM Post #212 of 593
I have a problem with my player. I was listening to my music and suddenly the music stops and this screen appears. Rebooting doesn't help. I can read my card on the player and on my MacBook. But whenever I choose a song this screen appears. I also rebooted the player. Nothings works...
Dec 14, 2023 at 6:18 AM Post #215 of 593
OK, order placed. I just learned that there is third party software to download tidal playlists/albums as flac. This fixes all and any issues I may have with this player.
Dec 14, 2023 at 12:14 PM Post #217 of 593
player was totally dead. charged for around 30 mins and player got to 43%
Dec 15, 2023 at 4:37 AM Post #218 of 593
I just got it. So do I understand correctly that the player does not connect to PC for file transfer? I need to connect sd card separately, upload music there and then plug it into the player?
That's a huge wt f. Good news that it consumed my 500gb Sandisk that I used in zx300 for years without any problem. Let's see what this little guy is capable of.
Dec 15, 2023 at 4:40 AM Post #219 of 593
I just got it. So do I understand correctly that the player does not connect to a for file transfer? I need to connect sd card separately, upload music there and then plug it into the player?
That's a huge wt f
Yes it is.
But the (real diehard) audiophile must suffer :dt880smile: :beerchug:
Ergonomic wise, they're a lot of limitations. But sound and musical wise, this DAP is my reference.
Against a lot of so said (very hyped and expensive) "references" (R8, N8II, etc)...
Dec 15, 2023 at 5:49 AM Post #220 of 593
Yes it is.
oh yes, they did something very clever with it. I'm one of those people who usually can't hear a meaningful difference between sources.
Aune definitely did some sort of DSP trickery here, it sounds distinctly different. But I really like it so far. Also dead quiet black background with sensitive iems.
Dec 15, 2023 at 5:56 AM Post #221 of 593
Yes.
The FPGA architecture works to sound it in such ways.
Dec 15, 2023 at 5:57 AM Post #222 of 593
Yes it is.
Same here. My choice of DAP for testing IEMs. So good.
Dec 15, 2023 at 6:05 AM Post #223 of 593
Yes.
Crystal clear, black background, natural, responsive, explosive, liquid....
Dec 15, 2023 at 7:22 AM Post #224 of 593
mine seems to fully charge in just over an hour. cheers
Dec 15, 2023 at 8:57 AM Post #225 of 593
This + Ripping Tidal Playlists + Bulk Rename utility (the player will play track 111 before track 12, so you have to rename 12 to 012) = I doubt I would ever use bluetooth.
Caveat, I only listen to IEMs so I don't need a lot of power from my sources.
And M1p sounds surprisingly 'better' than my trusted old Celsus Companion One. Pretty much every other thing I've listened sounded either worse (high noise floor) or approximately the same (wire with gain). But this thing does 'something' to the sound, specifically 3 things: bass impact, soundstage/separation and upper mids.
I can hear new things on Daft Punk - Motherboard (one of my test tracks) with this, which weren't retreived by any other source that I have heard.
@AuneAudio can you add ability to play/pause with screen off? This is the only annoying thing about this player that I cannot work around.
