No problem. I'll find out myself in the next couple of days when both the headphones and the aftermarket cable arrives. Thanks for the follow-up.
I own the Nightowl and strongly recommend to upgrade/change the cable. With the original AudiQuest cable the NO sounds okay, but I always had the feeling of some kind of unrealistic “pressure” on my ears. It was not relaxing to enjoy music.
As I m in DIY and have build many cables and components myself, I did a DIY headphone cable myself:
1 pcs. 3,5mm Stereo-plug to connect to Mojo (12€).
6m of 0,2mm/24AWG UPOCC Copper Neotech wire w PTFE insulation, 24€ (makes 1,5m cable).
2 pcs. 2,5mm Mono-plugs, 8€.
Slightly hand twisted and wrapped with PTFE to keep in place.
For less than 50€ the NO now shows its total potential, more dynamic, boomy bass is gone and now full clear defined bass notes, lower mid range cleared up, highs are without silbiance and no more fatigue, soundstage opened up. From time to time I always try the original cable, to make sure I’m not biased since the diy cable is my baby.
But I can not listen for one complete song with the original cable and have to change back.
The Neotech UPOCC wire is one of the best you can get with lowest distortion and information loss.
The Moon Audio cables may come close to this. I do own a Black Dragon USB cable and liked it between my source and Mojo.
However, that had been replaced by a JCAT Signature USB cable which is superior in all aspects.
