Audioquest JitterBug for the Dragonfly - USB Data & Power Noise Filter: does it work or is it snake oil?
Apr 24, 2018 at 2:20 PM Post #16 of 18
Get someone to help you do a blind comparison.
If it is making the sound "warm", it's probably just rolling off some of the high end. I don't know why that would be a good thing unless you don't like upper treble.
Apr 24, 2018 at 3:14 PM Post #17 of 18
I think this time the jitterbug is only bringing a very subtle difference...
Yes, the measurements I've seen do bring a very subtle difference. Unfortunately, it's a difference for the worse! They add noise/distortion, which is exactly the opposite of what they claim to do. So they're actually worse than snake oil, as snake oil doesn't help but it doesn't make the condition worse either. Fortunately though, the noise/distortion they add is very subtle and you shouldn't be able to hear it. I'd recommend a blind/double test as the only way to ascertain for sure if you can actually hear that added noise or just think you can. Or, you could just remove it from your playback chain and simply not have that additional noise/distortion in the first place!
G
Apr 25, 2018 at 10:00 PM Post #18 of 18
