DarkAngel
DarkAngel's a man, baby!
- Aug 22, 2001
Here is a very inexpensive tweak that is really quite effective:
Improved version II now available with 10bd more noise reduction, you buy 6-8 of these and create a "quiet zone" around your stereo system. Put them in the unused outlet of duplex wall outlet, used with an inexpensive Monster HTS2000 ($120 on the net) is very effective for stereo system. Place one with Monster outlet and use several for outlets on either side of stereo on same electrical circuit (quiet zone). Be sure and use in other outlets with stuff that puts a lot of noise in your electric line ie: computer, TV, refrigerator etc. Does not limit power in any way, and can be used with other PLCs. For $300 you can buy Monster HTS2000 and 6-7 Quietlines and you will get 50% of improvement that $1200 PS Audio P300 delivers with none of the negatives.
Check out this discussion at Audiogon about quietlines:
http://audiogo5.iserver.net/cgi-bin/...5004&read&3&4&
I bought 8 and am very pleased with the results, very cost effective tweak. I got a set of 8 for $179 at Galen Carol, or you can buy for $25 each from elusive disc. Need at least 4-5 to work (quiet zone creation), and 8 is ideal for typical stereo/home.
http://www.gcaudio.com/gcasteals.html
