fliz
link? I want to learn more about this OS.custom OS named Opal
Side note: a linear power supply for your RPi can make a massive difference in a high end system.
I already have every possible tweak and upgrade in place thanks.link? I want to learn more about this OS.
I tried the Aurender and sold it as I found it too complicated using WiFi to use as my digital source. I now use an iBasso DAP that has optical out via the 3.5 mm jack that is sent via a TOSLINK fiber optic cable to my Chord Hugo Upscaler that then feeds the DAVE DAC via dual BNC.
It looks like the upscaler has three options for digital input including optical in via TOSLINK, BNC IN, and USB IN. I decided to go with optical to reduce EMF and problems known with USB.
I want to stay with optical in as it has worked well for me in the past. My DAP battery died, so I am looking for another inexpensive digital source like another DAP, iPad (not a laptop computer) etc that I can store my FLAC music files and have simple software to allow albums and artists to be searched and then sent to the Upscaler. A simple user interface, a slot for a micro SD card and optical TOSLINK digital output is what I am after.
Is there a DAP under $1000 that still offers 3.5 mm TOSLINK optical out with an easy responsive software user interface and touch screen? I have searched all over and most DAPS no longer have optical out via TOSLINK and only coax.
Thanks. Yeah, I can upsample in JRiver Media Center but I don't so no interest in HQPlayer. That's me.Your pc is ready for Hqplayer. Should try itl
Since the audio signal passes through my router
Furutech outlet--->custom powercord--->linear power-->common noise filter-->supper caps-->RPi via GPIO pins to bypass internal switching supply from its power connector.
I have an Eversolo DMP A8 and at times use instead my laptop running audirvana through fidelizer pro. The laptop is clearer and more detailed than the Eversolo. So I think a properly setup laptop competes with a dedicated streamer.
I talked to BrianI've been meaning to call Brian again, because I'm curious what his thoughts are on ac filtering before the transformer. Common mode chokes, and emi filter caps across the rails are commonplace, but I'm not sure if they'd offer any benefit when using a reg like the Belleson SPHP.
I guess that depends on one's perspective. As one who's been running a Plex NAS server for the last 5 years, I disagree. I also happen to be a PC builder.I have found PCs to be too high maintenance to be a reliable music server and dedicated streamers have never quite hit the mark for me on price/performance/usability.
What "R2R DAC"?That said, I did buy my first R2R DAC and will be experimenting running HQPlayer on a separate machine with more horsepower which complicates things. If it isn't reliable I can alway just drop back to what works.
Happy to answer your questions as a fellow PC builder of several decades. I love to build and tweak computers, but have found that single function devices have been much more reliable for me over the long term.I guess that depends on one's perspective. As one who's been running a Plex NAS server for the last 5 years, I disagree. I also happen to be a PC builder.
So yeah, perspectives.
What "R2R DAC"?
Anyway, I find it odd you complain about reliability and complications yet introduce all those other elements into an unknown environment.
When I say I build, I speak of > recent. And I've only been doing it consistently since 1998Happy to answer your questions as a fellow PC builder of several decades.
Which R2R DAC: Bought a Cyan 2. I can run it reliably off my mini PC with Roon upsampling in PCM or DSD, but I want to tinker. Thats where I am going to use my daily driver 2019 Mac Pro to run HQPlayer and play with settings, but with a reliable fallback to the core system of the Mini PC.
I don't know you so I would just say use what makes you comfortable. That's what I'm doingI am curious. What do you use and what would you suggest in my situation?
Per your response, and re-reading your question, I'm not sure I understood your question, and thus my answer, so I put it this way - this >my gear.Cool. You do you!
