Audiocom Superclock 3. A $300+ mistake?
Mar 7, 2005 at 7:41 PM Post #16 of 48
If you want a picture of the LC Audio SuperClock x03 with the Clock Supply, then here are my pictures:
LC Audio SuperClock x03:
Clock Supply:
Mar 7, 2005 at 7:47 PM Post #17 of 48
LClock X03 Specs:
Black Gate NX HI-Q for noise free voltage filtering.
Dual Clock Output with UHF plugs (SMB type).
Instant Clock Signal, Main capacitor bank is delayed for trouble free integration in any CD / SACD or DVD player.
3V / 5V output level setting on board.
New Ultra Low Noise Voltage Reference from Analog Devices.
RG174 COAX cable with SMB plug included in each kit.
New Ultra Fast (5,2nS) Voltage Comparator (with factor 10 better signal/noise performance compared with XO2).
Disable function for DVD players with Standby mode.
4 separate Voltage regulators, compared to 2 in XO 2.
4 layer circuit board with two noise screening planes inside.
1 ppm accuracy (+/- 16 Hz for a 16,9344 MHz clock).
Jitter factor 10 lower than other leading ref. Clock.
Effective Voltage Polarising security.
Voltage monitor with Blue 'OK' LED.
Advanced Low Noise Design (91 active parts - compared with 43 in XO 2).
-Ed
Mar 7, 2005 at 7:57 PM Post #18 of 48
Mar 7, 2005 at 8:02 PM Post #19 of 48
I'm pressed for time today between studying and work tonight. I'll try to open up my unit carefully tomorrow and I'll get you the specifications. My hunch is that those are some premium Black Gates capacitors, but I can't tell you more until I open it up tomorrow. I'll snap some "macro photos" (whatever) for you tomorrow.
Mar 7, 2005 at 8:06 PM Post #20 of 48
Awesome!
Thanks.
-Ed
Mar 7, 2005 at 8:51 PM Post #21 of 48
Thx Welly Wu, way too much of a pain for me to get my unit out of it's parking slot and back in again. Ed, you are taken care of, right?
- walk
Mar 7, 2005 at 10:30 PM Post #22 of 48
- walk
He posted pics of the LClock X03.
You have the Superclock 3, right?
-Ed
Mar 7, 2005 at 10:33 PM Post #23 of 48
One thing I really don't like about Audiocom is that they don't publish any hard numbers or specs.
And considering the cost of these cost upgrades, I'll bet I the number of people who have actually tested different clocks side by side on identical players/DAC's can be counted on one hand.
-Ed
Mar 8, 2005 at 12:57 AM Post #24 of 48
Oh, yeah, that's right. I have the superclock3...that's the clock you want. Edwood, I'm sorry, but it's a royal pain for me to get the cd player in and out of our wall unit. What if I emailed you my pix? You could then perhaps use your photo viewing software to close-up on the pix? Lemme know if you want to go that route, and I will email you my pix. Send me a PM if so.
- walk
Mar 9, 2005 at 4:30 AM Post #25 of 48
Edwood:
My Canon PowerShot 3.2 MP digital camera can't do macro photographs well. So, I decided to get you the information the old fashioned way by writing it down on a piece of paper. First, you should consult with Mr. Dan Wright of ModWright, LLC with regard to how he mounted the LC Audio SuperClock x03 with Clock Power Supply. The SuperClock x03 uses a Black Gates 25v, 4700 uF capacitor operating at 24.576 MHz. The Clock Power Supply uses a pair of Black Gates capacitors with 2200 uF each. That's as much information as I could get to you.
Anyway, here are some close up photographs:
ModWrightLLCPioneerEliteDV-59AViLCAudioSuperClockx03TIBB1738EDACSAD8620AnalogeStageOutput.jpg
LC Audio SuperClock x03 Clock Power Supply:
Mar 9, 2005 at 7:39 AM Post #26 of 48
Are you sure the 4700uF 25V is a Blackgate?
I checked around and the closest FK series I could find was 4700uF 35V, and not only is it more than half the cost of the LClock X03 itself, it's waaaay to big to fit on that board.
Maybe the one on there is a Standard Blackgate?
-Ed
Mar 9, 2005 at 11:24 PM Post #27 of 48
Edwood:
I am sure of it. If you have any further technical questions, then I would suggest that you contact Mr. Dan Wright of ModWright, LLC at http://www.modwright.com . He should be able to answer your questions with regard to how he has chosen to install the LC Audio SuperClock x03 with Clock Power Supply. Please note that I received a package deal price for extensive modifications to my Pioneer Elite DV-59AVi and he said that my package offered the highest value in the sense of a performance : price ratio.
Mar 10, 2005 at 1:01 PM Post #29 of 48
Edwood, call or email Brice at SO about comparisons between the superclock 3 which he put in for the modded cd-25 he did for me and trichord research 4. It was my decision and impetus to go for the SC3 over the TC4, and I paid a premium for it, but Brice can offer some insights as we was able to make some direct comparisons.
- walk
Mar 13, 2005 at 7:27 PM Post #30 of 48
I like the Superclock3 over the other clocks, but I also modify it. If you install one of these, you need to pay attention to power wiring and output transmission-line effects. At 24 MHz, if you keep the cables short, it will probably work. It will make an improvement to the Bel Canto.
