m-i-c-k-e-y
Think you could disable the HP output thru: Settings > HP Detect "OFF"
I’m using it with Cayin iDAP-6 through I2S, PS Audio standard.Has anyone tried this with another streamer using i2s? From what i understand there is no standard for i2s at the moment and i wanna know if these play well with other streamers.
So the Hub does the upsampling and you keep Direct DSD "off"?I recently got the triple stack and am really loving it. I thought directdsd and dsd512 upsampling would be the way to go but I'm preferring the pcm 705/768 upsampling instead
Seems like my Shanling ET3 with its upsampling on is really good. PCM192 via coaxial sounds much better than native CD 44.1.I also have the 'hub and after many trials the best solution is: with filters in Linear, DSD off and Upsampling off, so native signal.
Thank you Franco. I noticed that DSD "on" sounds more constricted than off. I thought maybe it was my perception and wanted to hear opinions of others. You are confirming my impressions. Thank youI also have the 'hub and after many trials the best solution is: with filters in Linear, DSD off and Upsampling off, so native signal.
Ahh I appreciate it. I will just stick with my Aurender unit. It sounds fantastic. Not sure yet whether to go Coax or USB. Some suggest that the Coax on my aurender is better than the isolated USB. But that is beside the point.I had HUB for abut 6 monts. That is the only product from AB that I think did not like. First of all it did not have USB external storage input. Second..DSD option was sounding bad an much worse than higher numbers of PCM upsampling. I had it compared with my Rpi based streamer with Ian Canada gear & Aurender n100l. At the and I have sold it. I must say that HUB did really good job upsampling my old CD player. With your Aurender model I really think you don't need any better. On the other side I think that AB ZAP+VOX combo is one of the most exciting DACs for money in SH. I also like and use Direct DSD ON with stereo system & speakers.
