SonnyMarrow
- Dec 4, 2016
Look at the release notes, you only need 153 or 154, not both
Ah thank you. I also adjusted all the trimmers so I think I’m good to go.
I don't know if you have the HUB (must have access to internet) but this morning I was able to update thru the HUB using the attached instructions. It was super easy. I guess Audiobyte just got their update server running last night.How do I initiate the firmware update? I've tried playing the .wav file in both Roon and Musicbee using ASIO, and nothing seems to happen? The manual says a progress bar should appear, but I'm not getting that.
It also seems you have to turn off/turn on the Hub after an update. Mine kept updating the SYS module until I did that. After that it said there were no updates.To fully update. You must do it multiple times until all modules are fully updated. On me, have done it maybe three times until it's all done.
I personally believe the 0.2 delay bug is related to the constant clicking of the Vox, even if the sample of the Hub doesn't change. Nicolae said that the Vox would get a firmware update for that issue. I never had an issue with the Singxer so I'm not sure what it has to do with the Vox but that's the information I got. So I wouldn't be surprised if a Vox update is needed to fix the 0.2 delay bug.Do you guys know what exactly this update was about?
The 0.2 delay bug is still there...
I don't have Vox (I have Wavedream) and the 0.2 delay bug is still present. Nicolae confirmed that the bug is affecting the HUB.I personally believe the 0.2 delay bug is related to the constant clicking of the Vox, even if the sample of the Hub doesn't change. Nicolae said that the Vox would get a firmware update for that issue. I never had an issue with the Singxer so I'm not sure what it has to do with the Vox but that's the information I got. So I wouldn't be surprised if a Vox update is needed to fix the 0.2 delay bug.
With my current workaround (partial Roon upsampling and using SPDIF) I have no constant clicking and the 0.2 delay is no longer an issue either. It's annoying though that they still haven't fixed that issue because I'd really like to switch back to USB.
Ah ok. All I know is that they really need to get their act together. Still can't register the device on the support site. No manual. No fixes for the major issues. No support for the Hub in the app. Can't trust anything they say about time frames.I don't have Vox (I have Wavedream) and the 0.2 delay bug is still present. Nicolae confirmed that the bug is affecting the HUB.
I received an email too and was just checking. It's only partially fixed it seems. When I switch back to USB the 0.2sec delays are still there when I switch between songs . The delay does not happen for instance when you go back to the start of the song. If I remember correctly the delay used to be present before when doing that. It also causes less relay switching with the Vox now. Before it would trigger no matter what you did. Now when scrubbing through the timeline in a song it no longer triggers those.I have received an email from Nicolae where he is stating that the delay bug has been fixed with the update to 1.05
I have upgraded already to 1.05 but the 0.2sec delay is still there. Before I reply to Nicolae...can some of you confirm the same?
Are you sure? I just tried LAN mode on the Hub and I still get the delays. I'm also using the Vox with IIS. It doesn't happen when playing a single album (source sample rate stays the same then), but when playing random songs I still get the delay. Does your Roon server do any upsampling?○n my hydra stack configure : roon server →LAN switch → hydra hub(mode LAN) → hydra vox(mode iis) → headphone
0.2 second can be fix on this configure
hydra hub upgraded already to 1.05
to me is a happy news
use roon playing random songs, any sampling rate not have 0.2sec delay ,and my vox is always connect not have relay sound,except change sampling rate like 44.1 to 48 or 96KAre you sure? I just tried LAN mode on the Hub and I still get the delays. I'm also using the Vox with IIS. It doesn't happen when playing a single album (source sample rate stays the same then), but when playing random songs I still get the delay. Does your Roon server do any upsampling?
