Beyerdynamic DT1990 & Audio Technica ATH-R70x
Comparisons/Thoughts
I took delivery of the DT 1990 Pro today. I have heard them in the past and was very impressed with the imaging.
The R70x has been my daily driver for a while now and is probably my favourite headphone ever. However, as we all know, this hobby is never done and we are always looking for the next 'improvement'. Will the DT1990 offer that? Well, we shall see.
This isn't supposed to be a review as such, but simply a comparison between these two headphones. It will be useful for current R70x owners in deciding whether they would like to purchase the DT1990. Or for someone who is considering one of the two options.
So...let's get started.
Oh, and just for reference, I am using the analytical pads on the DT1990
Build
Despite all of things the R70x excels at, it will never be renowned for build quality. The build is rather 'basic' and somewhat flimsy. However, despite this, I would not say that they are prone to breaking or cracking. The grills look very classy and the wing system is a good one for stability.
The DT1990's however, can be described as nothing short of regal build quality. They're extremely sturdy and industrial, and there is little to no plastic used. The cups are all metal and have laser engraving. The headband is real leather and of high quality.
The conclusion here is an easy one. The DT1990 is far superior in build quality and is quite possibly the most well built headphone in existence.
Comfort
There are a number of people that have issues with the Audio Technica wing system. I am not one of them. I find they fit my head very well and while the clamp pressure of this headphone is very low, it never feels too loose. The pads, while fairly thin, are of good quality and mould to the ears well. There is something to be said for lightweight headphones for long mixing/listening sessions and these are no slouch in the comfort department.
The DT1990's take the comfort of the 880/990 and further, yes further, improve on it. I find the clamping pressure to be
perfect, not too light, not too heavy. They hit that magic sweet spot of being heavy enough and clamping enough for a feeling of sturdiness and comfort, but not too much as to be fatiguing/cumbersome. The pads being velour are very very soft and sit on the ears like pillows. I can wear them for hours with nay a hint of a hot spot, and no, I don't find them too heavy.
I think personally, you would be very hard pressed to find a more comfortable headphone than the DT1990. Think a Fidelio X2 or 880, but even better. While the R70x is still very comfortable, the DT1990 is a fairly easy winner here again .
Sound
Firstly, I would say that after listening to both of these headphones extensively, I don't consider them largely comparable in many areas. While they are both classed as 'reference' headphones, they both handle sound rather differently.
The R70x I would consider as flat as a pancake, at least to my ears. If you're looking for the 'flattest' headphone of the two, then the R70x should undoubtedly be your choice. There is no other headphone I have heard that sounds so 'flat' to my ears. The bass is tuned perfectly, albeit lacking finer detail. The mids are the very definition of neutral and musical. The highs are extremely mellow and non-fatiguing. Couple this with a very lightweight build and you have the ideal mixing tool for ensuring your mixes are as accurate as possible. Honestly, this should be the reference go to, not the HD600
The DT1990's are also somewhat honest, however they have more character. The bass certainly extends deeper and is more impactful, cleaner.The mids are a little more recessed but still display musicality, especially with instruments. The highs? Yes, they're elevated, especially around 8khz. This can make them more fatiguing and sharp, however, the highs here are extremely detailed.
Below will be a more detailed analysis of the sound -
Bass
The R70x in my opinion has excellent bass. It extends deeper than many of it's rivals and thus displays a wonderful warmth that is often missing from it's peers. Sometimes what are classed as 'accurate' headphones are severely lacking in the bass department. There is just enough bass here to still be honest and enjoyable, but not too much as to bloat the mids, or destroy accuracy. Not the most detailed of bass, but very accurate and musical.
The DT1990? Wow. The bass here is just phenomenal. It extends deeper still compared to the R70x and is more defined and resolving by quiet a margin. Sub bass is almost always missing in open back cans...but not on these. They pack a serious punch, and for an open back, it's quite outstanding. Hip-Hop listeners will rejoice. Thankfully, while the bass is plentiful and extends, it does not bloat the mids. Nor is it excessive. Just extremely well defined, punchy and accurate.
Both cans have better than average bass. However, the win has to be given to DT1990 here on sheer definition, extension and impact.
Mids
This is probably the most difficult portion of this analysis for me to gauge. People who have followed my posts in this thread will be aware of the fact that I believe the R70x to possibly have the most lush, musical and smooth mids of any headphone. I still stick to this belief. I mean, the tone and character is just
spot on. Vocals are smooth and angelic, and instruments have such a wonderful tamber and tone.
Listening to the DT1990 does
not feel like a come down, simply a somewhat different approach. The mids are a little more recessed meaning the vocals are ever so slightly less present and warm. This is not a bad thing in itself, however, in some recordings, a certain soul or character can be more elusive. However, I feel that the 1990's render the tamber and tone of instruments
even better than the the R70x. What is slightly lost in vocal presence is made up for in incredible tone of instrumentation. I never thought I would concede that a headphone has better tamber and tone than the R70x, but I think we have found it. Honestly, strings and pianos on these are simply divine.
I am tempted to give this one a tie. From a technical standpoint, the DT1990's are superior, but where one delivers vocals the best, the other delivers instrumentation the best. So a tie.
Highs
This is going to be controversial, but for me, this was an easy win to one headphone.
The R70x does
not have poor treble in the slightest and is, I would argue, absolutely perfect for long listening and audio mixing. It is mellow and subdued, and is thus extremely non-fatiguing. I believe it is
spot on for audio mixing.
The DT1990 while having peaky treble, are
extremely detailed in this regard. Highs are rendered with laser like precision and definition. People often get confused with exaggerated frequency response, and actual resolution. Headphones can have peaky treble and are said to be 'very detailed'. In many, this is not the case, they are simply exaggerated, and faked detail. This does
not apply to the DT1990. Yes, the treble is peaked, but, it is also staggeringly detailed. Hi-Hats, cymbals etc are rendered with such amazing crispness and resolution. Honestly, these put the HD800's to shame in regards to treble. The tesla drivers have incredible resolution. A quick reduction at 8khz of 4db with a Q2 will have these sounding less sharp, but every bit as detailed.
So, it's an easy win for the DT1990 here.
Soundstage
I find soundstage to be a hugely subjective aspect of headphones. Some will tell you a certain headphone has a wide stage, another, will tell you that they are narrow. It's very inexact.
The R70x to me is rather intimate, but not what I would deem narrow. If we use a HD600 as a reference, they are perhaps 10% more wide.
DT1990's are noticeably more wide. Instruments and detail are wider by a fair margin. I would approximate that they are about 50% wider than a HD600.
On technical terms, the DT1990 wins here, but I have always thought of soundstage as largely preference based. Some prefer intimacy, some prefer width and space.
Imaging
I have always said that the R70x has great imaging, and I stick by that. Instruments are defined, and are rendered very accurately. This is why, despite their fairly narrow stage, they feel fairly wide.
DT1990's however, have
insane imaging. It is pinpoint and extremely defined. You will hear to exact angles where different instruments are. A guitar may be right in front of you, and you will be able to deduce that a tambourine is 5 degrees to the left. It is pinpoint imaging and honestly scary. This is the sole reason I purchased these after being so impressed a while ago when I heard them. The imaging here is honestly unmatched.
Power
Both of these headphones are fairly easy to drive due to high sensitivity, and I am using a JDS Atom as reference. Not the most amazing amp but very capable and a good popular reference for many people
The R70x can be powered sufficiently off motherboard audio or even a phone. However, an amp is always recommended and these really shine with a tube amplifier. The JDS Atom was set at high gain and 12 o clock to achieve my ideal volume of 85db
The DT1990's are easier to power still. Not by much, but a little. The dial on the JDS Atom was set to 11 o clock to achieve the same volume as the R70x at 12 o clock.
Conclusions
So, by reading this analysis, many would deduce that I like the DT1990's more than the R70x? Perhaps. But no headphone excels at everything and renders another useless.
Make no mistake that the DT1990's
are the superior headphone in most respects, but this does not account for everything.
The R70x is perfect in my opinion for any situation where honesty and accuracy is needed. Audio mixing, very critical listening and production work. A case can also be made that they are better for long listening due to their light weight, and very non fatiguing treble (although this is sort of a non issue in the DT1990 once the EQ has been applied at 8khz)
On the other hand, the DT1990's do have superior build quality, comfort, bass, treble, sound stage and imaging. For general listening and highest quality possible, they maybe superior. DT1990 gets very little wrong, and where it excels, it is a master. The imaging and treble resolution is particularly impressive. Honestly, jazz on these is nothing short of a jawdropping experience. Also, Like A Prayer by Madonna on the DT1990 maybe one of the most awe inspiring audio moments in my life.
Do I think any less of the R70x? Absolutely not. It has wonderful tone, tamber and accuracy. It is as flat as a pancake and the ideal reference headphone and should, in my opinion, be the standard for audio production.
However, if you're looking for better bass, spectacular treble resolution, insane imaging and great sound stage...you could do a lot worse than the DT1990
Pictures
