Hi fellas,
As you can probably guess, I'm wondering which of these headphones to pick.
Here's a also a little bit of background. My current setup uses the onboard audio of the Aorus H370 Gaming WiFi motherboard, i.e. the ALC1220 audio chip.
I've been using the HyperX Cloud II headset. However, I wasn't much impressed with the 7.1 soundcard included in the package. In fact, when using the USB dongle, there appears to be some noise introduced in the headphones on higher volume levels. I was more impressed when I connected the headphones to my MoBo audio and played a little with the Realtek equalizer.
I'd say I like stronger bass levels, with reduced mids and slightly increased highs.
Anyways, I've been gifted a Creative Sound Blaster Z sound card, which I'll be installing in my PC some time next week.
The headphones mentioned in the title are available through some very good offerings in my country's second hand market and are pretty much at the same price, so consider as if they all cost the same.
My first question, I guess, would be if I will notice a difference with any of them over the Cloud IIs (which are based on the Takstar Pro80) connected directly into the Sound Blaster Z.
Secondly, if yes, which of these 3 would you recommend? From what I gathered online so far, the audio quality on the ATH-A900x would appear to be slightly better of the bunch, would you agree with this? The only problem is their design which has 2 wings for overhead support, which allegedly loosen up with time and they start to lose their comfort. Again, this is only gathered from reviews, so please share if you have personal experience with them. Another point is that the bass on the A900x is not as well pronounced as the one on the BeyerDynamics, which have 4 control options on the cans themselves.
I've also come across another offer for a Razer Tiamat 7.1 v1 and they're almost dirt cheap due to some visual defects, which I believe I could fix though. The problem with them is that I've seen many reviews reporting that while the 10 physical drivers give extreme situational awareness, the audio quality has been sacrificed in order to fit them all in a headphone package.
I should note that I'm using my PC for gaming, but also casual watching movies, listening to songs, etc. So I suppose I'm looking for a jack-of-all-trades headphones that have good bass and are a noticeable improvement over the HyperX Cloud IIs. Do any of the headphones listed above fit into this description, or would you recommend me to stick with what I have?
Another thing to note - the BDs would be bought brand new, whereas the AT and Senns are second-hand (even though the sellers assure they've been barely used and they look preserved visually). What is your opinion on buying used audio tech?
