Audio-Technica AT-BHA100 & AT-DAC100
Apr 16, 2024 at 5:05 PM Post #151 of 154
I'd like to replace the stock JJ tubes with Genelex Gold Lions. But since I never use the 6.3mm SE, I'd like to save some money and just swap out the 2 on the balanced channels.
How do I identify the 2 tubes I need to change?
I have not looked deeper into the board just yet to confirm this.
What I do have are infos on what’s plaguing some BHA100. I was at the recent Axpona and have spent most of my time with the AT folks at their booth. This issues is with the volume pot on B channel/balanced hp out in which a solder fails or come loose and will short out producing loud volume on the left channel. It will come and go. Mine has this issue and they also have this issue on some of their units. They know of this issue and will fix it for you via warranty claim.
Apr 17, 2024 at 7:59 AM Post #152 of 154
Well, once you've figured out which tubes drive which channels, please share the info here. Thanks.
Aug 16, 2024 at 3:37 AM Post #153 of 154
Hello everyone, unfortunately im here to ask for advice and tech support!
ill be brief at first with the problem at hand and then Ill explain how it happened
Part 1: the burnt integrated circuit
1. On the first attached image theres an integrated circuit that burned, it even smelled, in fact 2 of the numbers/letters in the chip visually melted so I cant look up the chips name.
2. The chip is very near to the power switch and and the output stage is close by as well.
Whats the result?
THE AMP IS WORKING, I checked than nothing else had burned or shorted other than this part, the result is:
-The power button switch does nothing at all, the power stays on if the amp is connected.
-Every single output except 1 including the preamp line out has hiss noise on the left channel, the hiss stays the same volume regardless of moving the amps volume pots.
If you ignore the hiss the amplifier sounds just like it should, and so does the line out.
-There is 1 single headphone out that is unnafected by the hiss and works exactly as intended, the uppermost/leftmost 6.35mm output works like nothing happened
-Tubes have already been replaced with spare matching tubes with tje exact same result.
If anyone could provide the name of the burnt integrated chip so I can maybe look for it that would be nice.
Im Also contacting Audio Technica to see if they can sell me the integrated I need, but im afraid they might ask for the whole amp to be sent instead which is problematic because im currently in MX and taking the amp there is quite extra effort and money
Im the first owner, I imported the amp from japan in 2022
I was trying psvane 12ax7 matched pairs, they sound great, I used them for at least a month.
It was mint condition until very recently I was trying to unscrew a rough torx and accidentally hit the power button very hard on the inside and It got misaligned, so It would not stay on snucked in (powered on) until i put it back together.
Part 2: Day of the failure
1. I listened to music for about 3 hours
2. Suddenly theres an annoying hiss on the left channel of every output, and I started checking the outputs, cables, hps. The hiss is really hard to hear on high impendence hps but still there.
3. 1 hour later while still checking my gear I smelled a slight burn coming from the amplifier but regardless it kept working just like before, with the same hiss.
4. After the burn, the power button stopped working, the amp stays turned on regardless of the power button's position, the amp has to be unplugged to turn it off.
Sep 13, 2024 at 6:05 PM Post #154 of 154
Anyone rolled all four tubes yet? Or using other tubes on their BHA100?
I was thinking of getting 4 tubes BUT decided to get a Vali 3 instead. Been using the Vali as pre-amp and started rolling tubes, that’s ONE tube instead of FOUR at a time. So worth sound wise, money wise and you get a tiny schiit of an amazing amp that could as a bonus.
