johnjen
Confirmed via email from tech support ("does not make use of the +51v power rail on the supply").
Excellent!
Thanks for that!
JJ
Excellent!
Thanks for that!
JJ
Well, I've upgraded to Rednet Controller v. 2 and while I can output sound, I can't get automatic sample rate change and my device (D16 AES) isn't showing in the device list in the left column.
What incredibly obvious setting(s) or action(s) am I missing?
The instruction manual isn't helping me out.
Thanks in advance for your help.
Joel
Joel
Do we even need the +-15 and +51 in the Rednet 3? Would it work with just the +5V?
Additional observation wrt "The PC *does* make a difference" ...
On my "silent" (= no moving parts) PC,
whereas I have had the o/s on a Samsung SM951 128Gb *M.2* SSD
and music files (*.flac) on a Samsung 850 EVO 1Tb SSD,
as an experiment I tried music files on the *M.2* with the o/s.
Whatever the explanation (same drive or just faster drive),
there is a definite and worthwhile elevation in SQ:
any digital edge I didn't know was there has gone,
more detail,
any comparison with analogue rendered much more redundant because the music is - well - just the music.
What's more and as a direct result, latency has dropped by 5-10 μs average and is undoubtedly more stable.
And so I have filled spare capacity on the *M.2* with my favourite music and will use the EVO SSD for storage instead of playback.
I am interested in a *U.2* drive as a possible future upgrade.
I have my O/S and Apps on 256gb M.2, and my music on 512gb M.2. I don't use my PC for anything else. If/when my 512gb gets full, I'll start putting music on the 256gb.
If you are able, please say whether there any SQ difference between playing music on the *same* M2 (as the o/s) vs playing music on a *different* M2 (wrt to the o/s).
If different drive makes no diff and it's just (M2) speed that counts I could consider a separate M2 for the music library. If same drive is key then probably a U2 would be my next upgrade.
Thanks
