robi20064
- Jul 27, 2014
Thanks, was looking at UK/DE/FR previously and only found this so far (still too high compared to $599):
http://www.axente.fr/undaes-o.html
For instance the Dante transceiver board is ≈ $2-300 (perhaps a bit less in quantity) but that kinda shoots the cheap solution in the foot, and that is only the ethernet input portion of this flavor of a DDC, and the PS and output electronics won't be cheap, if the goal is to keep it at the same (or better) level of SQ as the RedNet boxes.
Ok guys. Looked over the web for weeks to find any report for some cheaper AOIP alternative but could not find anything. Finally I took the plunge on the Atterotech unDaes-o that is a cheaper solution than the Rednet. As Bob also mentioned a few times it's based on the Dante Ultimo chipset. Confirmed this also with Josh from Atterotech. By the way he seems a super friendly person that supported me with some additional info on the product. I red what was to read about the differences between the Brooklyn and the Ultimo. Apparently the second one is the more recent but still lower cost solution limited to 24/96. No problem for me still since 99% of my library is redbook quality and my Theta Gen V cannot support higher then 16/44.
To cut it short, coming from my Singxer F-1 I still cannot believe how much of an improvement this little device brought to my chain. Just incredible. Tonal accuracy is unreal. Notes are heavier, more defined without losing speed. Bass depth and reverb with the HD800 is unbelievable. Treble is smoother, extended, more present with zero glare. Usually when I get new gear due to the enthusiasm of the "improvement" I tend to skip tracks without listen them till the end. For the first time this has become somehow difficult. I'm drawn into the music and it's like every track has some new beauty in it.
On each little tweak or even major upgrade I have found the HD800 to sound somehow not completely satisfying. The Auralic Taurus although being a solid state amp has been regarded as a warmish device. The Theta Gen V DAC for those who have had the pleasure to listen to is a R2R dac of the 90's and also falls in the warmer gear segment. Still I have never been satisfied with my HD800. Now and finally I can say everything changed and it seems the new Sony Z1R I was planning to purchase in the near future will be postponed for a good while. Cannot believe how much I was missing from my music although the Singxer was still such a great DDC.
I changed house recently and my system is still a mess but just to render a bit the idea I'm posting a picture since I think I owe it to the community
I'll try to shoot some photos by tomorrow. Here in Tirana is 1 AM so need some quality sleep now![]()
You can buy a full Dante Brooklyn II card for $185 retail - so I don't know where you came up with $200-$300.
cheaper AOIP alternative?
http://www.genelec.com/studio-monitors/sam-studio-monitors/8430a-ip-sam-studio-monitor
Ah, my bad, the last I saw it was in that range.
Thanks for the correction and good to know its cheaper than what I originally saw.
JJ
Opening the device doesn't look so simple unfortunately and I'm not risking voiding the warranty. Sorry Bob.
That image precision![]()
Just in case anyone was curious, I was able to find the Atterotech unDAES-O listed on FullCompass for $599. So, not cheap by any means, but still the lowest entry cost to AOIP so far. Now, if only we could get Focusrite to tweak their 2AM into an digital output device at $399, then AOIP would really start becoming the new "norm".
- InsanityOne![]()
High-quality clocks: Low jitter audio clock synthesis with sample-accurate time alignment between networked devices
Specifications
Physical
Electrical
- Input Connector: 1x RJ45 Ethernet
- Output: 1x or 2x balanced analog connectors
Analog Audio
- Power Consumption: < 2 Watt
- Power over Ethernet: Class 1 802.3af POE PD compliant
Dante Audio
- Output level (balanced): +4dBu @ 0dBFS
- Output Impedance: 150 ohm balanced or 75 ohm unbalanced
- Frequency Response: 20 Hz to 20 kHz (-/+0.5 dB)
- Dynamic Range: > 100 dB
- Signal to Noise: > 100 dB
- Total Harmonic Distortion: < 0.01% at +4dBu
- Channel Separation: > 100 dB
- Channel Matching: < 0.25 dB
- Number of Channels: 1 or 2 output channels
- Sample Rate: 44.1 kHz, 48 kHz (default), and 96 kHz
- Bit Depth: 24 bits
- Network Speed: 100 Mbps
Did you not read my post? You are confusing D-S vs R2R noise shaping by oversampling/upsampling with audio wave form interpolation upsampling like in HQ Player and Foobar/SoX. Yes they are both 'upsampling' as a process - but the implementations are different.
Then you confuse DAC 'oversampling' with 'upsampling' filtering with a NOS implementation.
