pataburd
The Sennheiser PX-100 would make a nice first step for you, I think. : )
Originally Posted by espire /img/forum/go_quote.gif Think that you should work your way up relatively slowly, which will give you more time to admire what improvements there are in each upgrade, and will give you more time to improve your listening skills, without which the more expensive headphones aren't as good. The first step, however, is the KSC75, and nobody will disagree with that. It's like Head-Fi initiation! |
Originally Posted by jdouglas /img/forum/go_quote.gif I 2nd the SR60, its a great bang-for-buck in the sub $200 range. I had the KSC-75's also, they're nice for money ($10-20) but can't touch the SR-60 IMO. The problem is once you hit $200 phones, that's when you really have to start considering a headphone amp... Also, if you're doing mp3's, in addition to 192 kbps, be sure to encode them as VBR (variable bit rate). You'll save a ton of space, you could probably do 128 VBR just fine too, and not notice any difference until you get much more expensive phones. |
