kingoftown1
- Jun 19, 2011
Double post
Try cutting and pasting: Xangsane HiFi pure silver fuse silver in the Ali express search engine.Did you see my series of posts a couple of pages back? Which included copper and titanium slugs, and the practicalities of obtaining a titanium slug.
Based on some comments at Audiogon, I would expect titanium to perform in the same ballpark as silver, with maybe different characteristics.
I've not yet found a silver slug online, and the recent Aliexpress link only took me to a general page, with no silver slug in sight. Not that it bothers me much, as I'm perfectly content with titanium, as it's much cheaper and much less prone to tarnish.
Thank you for the Ali Express link. I can now see it. [Edit: they also have rhodium-plated sliver, which may tempt me]Try cutting and pasting: Xangsane HiFi pure silver fuse silver in the Ali express search engine.
I do not think I saw the info on how to obtain the titanimum slug.... Are you referring to McMaster-car dowel pins. Could you kindly give me the exact product and link where to order them? ALso- I just dont get how to place the order. It seems I have to have a rod cut to a certain size. I'd appreciate the details....
I’m not super technical but from my reading on this topic the short answer is, I believe, even with a power conditioner including upstream voltage surge and over-current protection, by removing a current limiting fuse set at or near the maximum level the component can safely operate you are removing a safeguard against an internal fault/short in the component in the scenario where the current would have exceeded the fuse’s limit and the safe operating limit of the circuitry in the component potentially causing damage or a fire, but not high enough to trip the conditioner’s much higher current rated fuse.I would like to ask more about the saftey concern of sluggos.
First- we already addressed that a proper power conditioner, isolation transformer will add protection.
Second- I have a fuse in my home that all my equipment is connected to. So does everyone else. Wont that fuse jump if there is a problem? And if so- isn't the fuse in the appliance just another extra protective stem which is "extra credit" rather than obligatory.??
Third- all of us who use audiophile fuses bump up the fuse we use because audiophile fuses overreact to current and blow to easily. So- when we need a 3 amp fuse and use a 4 amp fuse- which is common practice;- isn't this basically also limiting our protection?
I'd appreciate technical minded people to address these issues if possible.
If the fuse in your fusebox is not more lenient than the Device connected would require, it does offer protection.I would like to ask more about the saftey concern of sluggos.
Second- I have a fuse in my home in my fusebox that all my equipment is connected to. So does everyone else. Wont that fuse jump if there is a problem? And if so- isn't the fuse in the appliance just another extra protective stem which is "extra credit" rather than obligatory.??
Third- all of us who use audiophile fuses bump up the fuse we use because audiophile fuses overreact to current and blow to easily. So- when we need a 3 amp fuse and use a 4 amp fuse- which is common practice;- isn't this also limiting our protection?
It basically saves the wiring in your house from starting to burn, but that's about it. At least to my understanding.Got it. So the fuse in my fuse box is 16A- meaning it gives me pretty much no protection for a component with a 1 amp. fuse.
Is that correct?
How often did a fuse blow for any device in your home, in your life?Is the possibility of fire in a component with a slug greater than being hit by a car when crossing the street, or having a sudden heart attack?
In other words- how low or high are the odds of a problem? If they are in the category of "similar to getting into a fatal or paralyzing car accident" and I get into a car every day, then I see no reason to worry. After all- I'm not planning to stop driving. If the odds of a component fire are higher- then I need to consider by how much.
Yes, that is mostly correct. But note that each cut wastes some of the rod, so you might only get, say, 9 pieces in practice.So- as standard small fuse is 5 x 20 right? So I'd order the 5mm diamater, than choose a length - say for example 200mm and have them cut it into 20mm pieces which would be 10 pieces. I'll hace to contact them to ask if they will cut it for me into 10 pieces????
I have no need for 10 fuses- but the 200mm rod is just 2-3 more pounds in cost than a 50mm rod- so it is basically free...Yes, that is mostly correct. But note that each cut wastes some of the rod, so you might only get, say, 9 pieces in practice.
Better to not worry about the starting length and just message them the number of pieces that you need. So just say: I need 10 pieces of 5mm dia. by 20mm length, and let them work out how they will achieve that.
10 seems a big number to me - even if this was only used as an example. As per the recent advice about safety, I would proceed with caution when bypassing any component's internal fuse (unless you add an SDFB). The probability of a serious issue is small IMO, but the impact could be high. And a low probability/high impact risk is still overall a risk to be taken seriously. Which is why all my fuse-bypass advice relates to a UK wall-plug fuse, where bypassing a (typically) 13A fuse is no risk at all when the component's much lower rated fuse (e.g. 1A) remains in the same circuit.
I live in Israel- and you better believe I have a ground fault circut. It is quite sensitive to shorts. When an appliance in my house has a short- it jumps and jumps fast.It basically saves the wiring in your house from starting to burn, but that's about it. At least to my understanding.
You should have a ground fault circuit interrupter in your home which should trigger first anyways. (I'm not sure which countries use those, but Germany does)
