I
have new threadPlease post pictures and details, maybe in a new thread.
I
have new thread
OK... I see now...
http://www.head-fi.org/t/839007/r2r-da-m1-ultracap-powered-build
I am looking forward to your final preferred configuration using the new Audio-GD r2r modules...
the info may be interesting to Singularity 19 users who would like to try some PS mods.
Just so I understand....
There are two versions of software/firmware to choose from with the S19 - neutral/normal and warm. This does not have to do with the jumper settings correct?
Possible firmware update/upgrade? Or possible to have both and flash between the two?
Just random thoughts.
-T
So I reinstalled ASIO Bridge - issue persists that I cannot open the ASIO Panel, and that when I try to increase latency it tells me to reboot but after that it's still at the same latency. Any ideas? All other devices are disabled except Hi-Fi Cable. I also tried enabling Amanero but still nothing different. I do get a bit of data loss/popping every once in a while on all sample rates.
Does anyone know of a sound card with multiple coaxial outputs? I don't care about headphone ports or analogue rca out - just coaxial or bnc.
-T
USB from PC do vary widely in quality. That is why recently I was tempted and tried a different approach to usb audio. I tested a USB device server - Silex DS-510 (http://www.silexamerica.com/products/connectivity-solutions/device-networking/usb-parallel-connectivity/ds-510/).
This unit kind of decouples USB from the noisy PC. The PC/laptop sends USB over IP (via a switch) to the DS-510 where the USB signal is freshly reconstructed. I feed the DS-510 with a linear power supply (Sbooster). Ethernet provides galvanic isolation. So now I have a very clean USB signal that is fed to a DAC or DDC (like Singxer F1). Better still, the USB signal is generated on the PC side by software purely - it is not negatively influenced by the USB bus of the PC.
This is another way to avoid crappy USB from PC and ... still stay with USB .
All this for about USD/EUR 90.00 (without the LPS)! Not bad at all
Audio-GD's first R2R dac is a great achievement; it is definitely recommended.
Please elaborate on your impressions!
Does the DS-510 need an aftermarket LPS to be a great solution?
Looking at the LAN Rover as well.
Thanks VilMo
