ohcrapgorillas
In my case I have only one SPDIF input to be replaced. Your case has three inputs, you could choose which input to be replaced.
I have to use a hand file to enlarge the hole to fit in the i2s HDMI connector, the back panel is 1cm thick, so it is some kind of rough.
I never seen a mini-HDMI board for i2s, if there is any, it may fit better.
I just find something handy to fill up the hole of 75R-BNC, it has no funtion.
If you could upgrade to i2s input, that is definite worth to try. i2s is superior than SPDIF input in all sense.
If you planned to try i2s input for your DACs, I suggest you take a look on the Audio-gd DI-20HE, that converts USB/SPDIF to i2s. That is the best DDC I tried in the last few years.
