Nayyte
Channel imbalance disappeared? That's interesting, indicating faulty decoder chip. Do you have U2/U2Pro version with standard oscilators?
DAC's balanced design will only filter portion of noise entering power supply of A/D converter and output buffers. There is also noise affecting clock frequency. Balanced design won't fix jitter, so there is still a room for improvements. If you read a U2/U2Pro Poorman DDC thread, discussion is now focused on using USB isolators. Investment in the $50 dongle is never wasted when a source is PC. $100 device is probably optimal.
Yes I have the U2pro version. The sound quality improvement overall is immense vs. the older USB input on the Ref-5. I was getting +1 DB on the left channel before that I software corrected. With PC noise, all I know is that I hear it very loudly when listening to tube amps and that I hear none at all with the master-9p. Oh I meant balanced design of my amp not DAC.
