I have been using the bridge on the PWD from the first week that it came into my hands. I believe I tried the USB for a day or so in the very beginning, and then took for granted that everyone knew what they were talking about when they mentioned the superiority of the bridge. I haven't tried the Audiophilleo on the PWD either, which I should, as repeatedly I found it to improve my setup, in spite of the DAC. Maybe the AP2 is just my cup of tea, as it's the purchase that I find keeps on giving. As for you trying out the bridge, we spoke about this, and I definitely think you should. I won't say what it adds until I revisit the USB, but the PWD really is very good. While say someone like Purrin, with his resplendent ears, could pick the PWD's flaws apart with a surgical knife, I only ever found it to be lacking in one area, one zit so to speak that I cannot remove. There is a harshness or stridency somewhere in the upper-mids, a digititus that runs inverse to the very thing that makes this a great DAC: a union of liquidity and spirited dynamics. What's interesting in my system is that this doesn't produce a bright, tiresome sound, but instead takes something of the chroma or hue away from a recording. A homogeneity sets in and my interest in the music sometimes can start to grow dim. This is where I'm finding the RE7 and M7 rewarding, for it seems to enrich the music for me.
*I usually find that I agree with your views Darryl, so I'm a little surprised that we do not agree on the sense of weight from the M7. I don't know that it matches the electrifying dynamics and volume contrasts of the PWD, but instruments have a burly weight and presence in my system.
It needs to be noted that I didn't spend a lot of time with the HEX (2-3 hours) and also took the less accurate attitude of letting the music draw me in, rather than determinedly look to analyze. My hazy conclusion was that the HEX was very solid, particularly in the area of grain, where it was cleaner/blacker than the PWD by a fair amount. I also felt it may have been a little more resolving than the PWD, but this was on the order of subtle. The soundstage was also solid, but not anything you would go out of your way to talk about. With my Stax setup, the HEX was too halcyon compared to the PWD (which I feel does particularly well with the Stax). Tranquil and at rest is not what I look for in a DAC, and with the Stax at least, that's what it gave me. Also, the vocals on a certain album (Nick Drake's Five Leaves Left) were a bit closed-in compared to the PWD. I couldn't reproduce this closed-in sound consistently so I just chalked it up to a poor album match. As I was telling Darryl, to discriminate between two sources is a difficult task, and for me at least, takes time. It's usually the finer nuances that are discovered over time, and often unintentionally, which then provide an atlas for further understanding (the audio gd DAC's are the exception to the rule for me, presenting themselves different right away).
In short, the HEX was solid, with no glaring flaws, but a little too clean, a little humdrum, and did not provide enough variance to set it apart from the hodgepodge of DAC's in the 3k region. Again though, my time with it was short and ostensibly I kept my analysis-blade sheathed, so take that for what it's worth, which is not much.
