Audio-Gd Master 7 - Discrete Fully Balanced DAC (PCM1704)
Aug 21, 2022 at 3:31 PM Post #4,396 of 4,451
Have you considered the Pi2AES-Lite? Runs the same Pi2AES s/w. The specs are the same except for voltage input. Or does the +24V model just sound better?
https://www.pi2design.com/
Is there any hifi gear that supports AES3id? That seems like an odd choice of interface.
Aug 21, 2022 at 4:06 PM Post #4,397 of 4,451
For best sound experience with the old M7 upgrade the I2S adapter to HDMI hardware. Kingwa sells them pretty cheap at around $35us.
it can be powered by 5v from pins in stock form and from default power input after a minor change
Kingwa's I2S HDMI receiver is not the best option imho and it's not looks cheap at 35$ sorry
Aug 21, 2022 at 4:48 PM Post #4,398 of 4,451
Since the P2-Aes is out of production, does anyone have a good reccomendation for a DIY or already built solution to run I2S into the Master 7 Singularity?
I'm wifi streaming with a Raspberry Pi 4 now and currently run USB to Audiophilleo 2 with PP to Spdif in to MS7s, but really want to try an I2S into the DAC to see how much more I can get out of the DAC.
Di20/he.
Aug 21, 2022 at 4:51 PM Post #4,399 of 4,451
I used Audiophilleo 2 mk II with Master7 a few years ago, Pi2AES is completely another level. As options there are Allo Kali hat or Ian Canada's FifoPiMa
And am I understanding this correctly that I would USB to a unit that would then send I2S out to the MS7?
The Ian Canada looks like I could do that, but not the Allo Kali hat?
Aug 21, 2022 at 4:53 PM Post #4,400 of 4,451
Aug 21, 2022 at 5:13 PM Post #4,405 of 4,451
not exactly. usb is not needed. raspberry takes digital music from its storage or over the network then allo kali or ian canada hat will take digital signal from raspberry gpio, make it proper and translate to dac directly on i2s input, or by hdmi/aes/spdif transmitter - in this case you will need to add suitable transmitter. Pi2aes has built-in transmitters but these hats don't
Aug 21, 2022 at 5:19 PM Post #4,406 of 4,451
Aug 21, 2022 at 5:22 PM Post #4,407 of 4,451
How do I connect either of these units to my Raspberry Pi streamer?
Aug 22, 2022 at 11:36 AM Post #4,410 of 4,451
My M7s has an HDMI input already, so I should be good to go there.
