My setup is
Jplay,
Audiphils Optimizer,
Windows 2012 R2 Core,
Intel I7 Control & Audio PC's
Paul Pang Clock Upgraded ASUS Motherboards
SSD's Battery powered
Meicord Cat 7 Ethernet Cable
2 x HDPlex 100W Linear Power Supplies 12V to CPU's and 19V to motherboards
Paul Pang USB V2 USB PCIE card battery powered
Double Helix USB cable
Audio-GD DI-2014, TXCO, HDMI/I2S kit installed
Wireworld V7 Silver Starlight HDMI
Audio-GD M7, with HDMI/I2S DIY Kit replacing RJ45 input
Double Helix Balanced ACSS Cables
Audio-GD M10
Mad Scientist NEO Power Cord and Inline Purifer on the M10
Terrilium-Q Black Speaker and Jumpers about to arrive to replace current NAIM NACA5 cables
Magnepan 3.7R's
Assembled this equipment a bit at a time over the last 3 years. Most recent addition was the DI-2014/HDMI interconnect 2 months ago. Had this setup working now for 8 weeks. Before this, my last 2 configurations were the same as above but 1) Using Audiophilleo 2 and its Battery Powerpack and 2) Audio-GD M7 USB32 Version 1.
While running in the current configuration I had left the Audiophilleo 2/Powerpack in place so I can switch from that setup to the HDMI/I2S configuration using the M7 inputs selector, to then the M7 USB32 input by just moving over the Double Helix cable from the DI-2014 to the M7 USB32 input.
I would rate the configurations (subjectively) over two weekends of trailing as from top to bottom
1) DI- 2014 --> HDMI/I2S ---> M7
2) Audiphilleo 2/PowerPack ----> M7
3) M7 USB32
The M7 USB32 is an acceptable level of performance, but the detail, instrument placing and depth/width of spacing, just improves moving up the ladder. Initially I found the DI-2014/HDMI setup sound quite brittle but it settled down after about 3 weeks of running through on "shuttle mode' with some 'burn-in' tracks.
From 3) to 1) for an additional $160 + HDMI cable is a great combination at a great price IMHO
From 3) to 2) for an additional $900+ is not so great a deal financially
Any downside...perhaps. I cannot run Jplay in 'Ultrastream', have to use River, Beach or XStream. Cannot get buffers down to 'Direct' need 256, 512 and 512 for 44.1, 96, and 192. The issue there would seem to be the VIA USB32 driver used with the DI-2014 which will not work with Jplay at those lower, Optimum settings ?. But those settings working with A2/Powerpack are bested by the DI2014/HDMI combination. So perhaps sometime in the future a newer US32 driver, or changes by the Jplay team, might open up those other options in Jplay. For now I'm happy with this setup. Does make me wonder what an OR5 or the future OR6 might offer.....but for now happy listener with the DI-2014/HDMI
If you already have an M7 then the Di-2014 and DIY HDMI upgarde to the M7 is a still great upgrade at around $400+
Looks like I'l be selling the A2/Powerpack
Frizzup
