FredA
- Dec 15, 2013
The cybershafts are good clocks. Only connecting the di20he provides a clear benefit with a r7 dac. Likely so with all relocking dacs.Guys what do you think of these cybershaft OCXO clocks? It has lower jitter than a $23k esoteric clock and it only costs $1000.
https://www.whatsbestforum.com/threads/reasonably-priced-dual-master-clock-10mhz-rb-and-ocxo.20827/
Again probably I am wasting my cash as I will only connect a DI20HE to it if I order it.
The point IMO is reclocking has little incidence on low frequency jitter in general (can hardly be removed, basically stays as is) and the internal clock of the dacs have good figures otherwise. So having the di outputting a signal with very low low-freq jitter will bring a significant improvement with low bass response. But it is not only that,.for some reason, resolution and imaging improve as well. I am not sure the cybershaft in this price range is better than the Morion mv89a. Connecting the dac also brings even more of an improvement accoring to all headfiers thst have tried with an audio-gd r7.
