FredA
- Dec 15, 2013
[wrong thread]
I debated whether or not to post this, but I thought I would just in case it helps anyone.
First of all, Kingwa was *extremely* helpful during the process and quickly offered a refund for the DI-20.
@rsbrsvp Since you have both the externally clocked R7 2020 and DI-20HE (well broken in) have you made any comparison to USB into the DI-20 and USB direct to the R7 2020? All externally clocked.
The reason for asking with an external clocked DAC is the DI-20 even necessary? With my current setup (DI20HE and regular R7) I find less differences in sound quality with HDMI I2S or SPDIF or AES/EBU. They are getting closer in sound with each hardware and firmware upgrade. And there is a rumor that Kingwa is working on a new DAC digital board to replace the older 2017-2019 digital board. It will have external clocking capability so perhaps DIY upgrade for externally clocked DAC in the future . Just rumor, of course. But interested in how the externally clocked DI's USB sounds compared to externally clocked DAC's USB input.
And anyone else with the latest DAC and DI gear would like to hear your comments as well about externally clocking and USB input comparisons.
Could definitely be compatible.
Kingwa states it can match with most dac digital inputs.
Good morning all,
Could someone tell me if the BNC ACSS output is compatible with the BNC input of my Chord Hugo Mscaler.
Thanks in advance
@TitaniumDust That is unfortunate and glad you spoke out here. Were you connecting S/PDIF coax from the DI-20 to your DAC? If so wondering if the DI’s ACSS S/PDIF output circuit is compatible with your DAC? What DAC is it in case someone else has a similar issue? Could very well be an impedance methodology issue and why it works for Kingwa and not for you. Thanks again for sharing.
I did make the comparison. Why? I figured maybe I could sell my DI-20HE. Also- I find the external clocking has more effect on the R-7HE than on the DI-20HE if I choose to clock only one of them. However I found that with the DI-20HE externally clocked and the R-7HE externally clocked the sonics were noticably better IMHO than USB direct to the R-7HE externally clocked. It could be that those who have a low jitter source may not need the DI-20HE. I am using a a mac mini and perhaps one of these dedicated music servers may do a better job and eliminate the need to use the DI-20HE. I cannot know...
Thank you @Jackula for the info. I am estimating that mine was powered on for about 1 or 1.5 hours the first day, while troubleshooting. I left it unplugged overnight and then tried again the next day with no luck. Perhaps I will try the DI-20 again in the future after more info appears and more people report their experiences.For what it's worth, my DI-20HE also had no audio, no matter the output and I thought I got a dud unit. But after leaving it on for maybe 20 minutes the sound suddenly came through and I had no problems after that.
