Bech
- Jul 3, 2012
Can you please try to describe WHAT was improved? I would gladly upgrade to the Zen MK3 if the improvement in sound is there (and audible to me)!
I also play ONLY locally stored music. In my case, the Zen will be connected to an Eero Pro (mesh WiFi network) - just like this one: https://eero.com/shop/individual-eero-pro
Are you saying that I would benefit by dumping the generic Cat 5 Ethernet cable, and instead use what? Better LAN cable? (if so - which do you use / recommend?)
I do not even know if LPS exists for the eero... Being fed by USB Type C connector - I guess I could get a LPS that outputs USB Type C...
The Phoenix cost more than the Zen... Thanks, but not gonna happen here I think my DAC has a pretty good USB. Besides, I use a Gustard U12, and will consider upgrade to the DI-20 or DI-20HE in the near future.
Thanks @Bech for your notes so far. I really appreciate it, and hope you can answer my questions above
I made an A-B test yesterday between my iMac and Innuos ZEN as source. It took some time to shift back to the iMac, and I thought it sounded pretty OK and wondered if the ZEN was overkill. But shifting back proved I was wrong. Less distance to the music, less flat, voices and bas better defined and in general more naturel and “right” sounding.
I have improved my chain before my upsampler/DAC the past years and in general all improvements are in the same direction.
Try to watch Hans Beekhuyzen channel – ex. the videos about SOTM starting with the earliest. Darko has a good review off the ZEN as well.
Abouth the LAN cable. My first impression af the ZEN was that it was definitely better than the iMac but I felt I missed something. My friend with the Gustard U16 came by with his new hifi swich an other LAN gear – and this helped a lot! Next day I borrowed an used Audioquest carbon LAN cable – and was in zen from first minute – I felt more calmness an magic in the music. Later I have improved even more.
About the level of the U12 (and improve the power-supply) – se here:
https://www.usaudiomart.com/forum/viewtopic.php?f=35&t=1172
