Jandu
- Aug 13, 2010
Something for the 2024 New Year.
http://www.audio-gd.com/R2R/DI24HE/DI24HEEN.htm
What's new feature in DI-24HE:
1, Built in 50 and 75 ohm external clock input ports , for compatible with the external clock model output impedance (remove the spdif input feature of the DI-20HE, became the 75 ohm clock input feature ).
2, Built in 10MHz clock generator .The FPGA design the clock processor for reduce the jitter and phase noise, 50 and 75 ohm clock output ports that can work as an external clock , feed the 10MHz signal to the DAC. The clock outputs can switch between internal clock and external clock by user set on the front plate.
3, Fully isolator built in , not only the USB input with isolation, but the external 10MHz clock input with the isolation , through the isolation output connect to the DAC that can reject the power interrupt .
4, All output circuits power supply by pure class A PSU for get the better analog feeling sound, USB interface ,FPGA and clocks power supply by 4 groups DC serve power supply and 5 group ultra speed linear PSUs.
