I have the same grounding tube on my PLC, high five.No, I installed a 5.5/2.1 connector, which i use instead.
Audio-GD DI-20
- Thread starter soundlogic
FredA
- Dec 15, 2013
I have one my master clock output and dac input (neutral) too. Waiting to be upgraded with 1.5kg boxes. The tubes will then go on the dac analog outputs. Looking forward to it.I have the same grounding tube on my PLC, high five.
Looking forward to hearing your impressions.I have one my master clock output and dac input (neutral) too. Waiting to be upgraded with 1.5kg boxes. The tubes will then go on the dac analog outputs. Looking forward to it.
I really hope it doesn't make that much of a difference so I don't have to get one but considering how much of a difference that tube made, a 1.5kg box will probably be very impactful.
Which ones are you going with Fred?I have one my master clock output and dac input (neutral) too. Waiting to be upgraded with 1.5kg boxes. The tubes will then go on the dac analog outputs. Looking forward to it.
I've had these 2kg Quartz Acoustics ones highly recommended, just waiting till after the summer holidays (down here in the Antipodes) before maybe getting some.
https://quartzacoustic.com/shop/qa-premium-audio-ground-box-with-crocodile-clip-cable-included/
So many to choose from. A few people have tested them in the aliexpress cable thread with great results, I haven't seen that particular one though, just some unbranded variations of it.Which ones are you going with Fred?
Mr Brett
I have heard these are good...
FredA
- Dec 15, 2013
I got them on ali.I have heard these are good...
Mr Brett
I've got an SGS-1, Silent Point and an Aucharm.I got them on ali.
Maybe will try a Quartz Acoustics next year.
Is there any difference between them?I've got an SGS-1, Silent Point and an Aucharm.
Does one perform better than another?
Pics?
I'm very interested in these grounding boxes.
Mr Brett
I've only heard the SGS-1 in my full system.Is there any difference between them?
Pics?
Initial thoughts:
Smooth is one way of describing it.
My system has lost its digital sound over the last few months, with the grounding box moving it even further from that.
Will get to putting it all together next year, with the Silent Point and Aucharm in. Will use them on my streamer, Dac and DDC.
On WBF, someone thought the SGS-1 was not as good as others (although is the cheapest of their range).
FredA
- Dec 15, 2013
Got a 3kg silent point here and two Aucharms coming in on Monday.I've only heard the SGS-1 in my full system.
Initial thoughts:
sajunky
Right. In your setup it will be unused.
Answering your question in the other thread: connect your clock source both to DDC and a DAC, you need two BNC cables to do so.
FredA
- Dec 15, 2013
It's the clock input that matters. Looks like 75-ohm, not sure from the pic.
