seaninbrisbane
- Aug 9, 2010
I'm just about to order the Sabre version of this DAC - just wondering if anyone is looking to sell theirs? I'm in Australia.
Anyone using this amp with planars like t50rp or he500/lcd-2? This amp outputs 2000 mW at 50 ohm, is that right? Would love to hear your experiences with those headphones. Also how is the pcm5102 version of this amp, seems like a nice budget option
I have the compass 2 with all three dac modules. Of course I've done some dac-rolling to figure out which one I like the best and for the fun of it
The es9018 pushes detail and can seem a bit bright. The bass is neutral and it has a deep soundstage. The wm8741 has more bass, same deep soundstage and you can tune it with the filters to sound warm and fast at the same time if you like (8x oversampling, minimum phase, apodising filter), or more neutral and fast without getting too bright (8x oversampling, liniear phase, apodising filter) and so on... The pcm5102 also has more bass than the es9018, on the same level as the wm8741, but it is over all more forward and engaging than the wm8741 and the es9018 and this means the bass becomes more punchy and seems even more powerful than the wm8741. The soundstage is not as deep on the pcm5102 as the other two dacs, but it sounds more intimate and fun perhaps. There are two filters on the pcm5102. The FIR-filter is fast and powerful, good for details and fast paced music as you will be abled to hear everything separated and clear all the way down to lowest of low bass. The IIR filter sounds softer, the sound rings more out and with fast music this means the individual notes seem more together and not as clearly separated, and it also means that the bass doesn't hit as clearly and hard as with the FIR-filter.
If you're considering the compass 2, get all the dac modules to go with it. It's the only way to find out what you actually prefer.
The compass 2 is a strange and anonymous amp, it hasn't got a sound og its own, it's all up to you to choose what you want and the compass 2 will deliver in a most convincing manner I can tell you. It becomes a very personal product in the end when you're done finding out what you personal preferences are and have set the compass to point in your direction.
So don't ask what the compass 2 sounds like, the question is: what do you want it to sound like?
Someone questioned the amp design further back in this thread, so just to clear things up: the amp is acss, non-feedback, discrete, the works, on the headphone out.
Oh, by the way it has more than ample power for the he-500, k701 and the likes, I used both and power is not an issue, only flavor is
were you able to return the modules after or did you have to keep it?
I have the Compass 2 and wished it incorporated a balanced DAC/amp design with mini-XLR and SE output. Maybe this is something for the future - Compass 3?
It means I have to look for something in between.
Steve
Steve
The corresponding Audio gd balanced unit has been the NFB-10 for years. Recently the NFB-28 was added.
