Shaffer
- Sep 7, 2013
I have A5+ in my office system run in conjunction with a Klipsch blahblah-12 subwoofer. The x-over point for the sub is @ 65Hz (12dB/octave). The A5+ are run full-range. The "sub" you're using is essentially a woofer. 150Hz is relatively high and can be localized, meaning you know where the sub is. You want a sub, buy one, but make sure it's an actual subwoofer. FWIW, I have no EQ in any of my systems. No need. Good luck.
