It's not yet added to Oratory's database, but as they're my MM-100's I was sent the pdf.
I thought the same, and asked Oratory to try out an EQ I had made (obviously with no intention of discrediting Oratory's EQing ability, I haven't even had the chance to listen to them yet!):
Preamp: -6.2 dB
Filter 1: ON LSC Fc 57 Hz Gain 2.3 dB Q 0.710
Filter 2: ON LSC Fc 105 Hz Gain 3.2 dB Q 0.710
Filter 3: ON PK Fc 240 Hz Gain -1.6 dB Q 0.920
Filter 4: ON PK Fc 1038 Hz Gain -3.0 dB Q 1.540
Filter 5: ON PK Fc 2002 Hz Gain 5.2 dB Q 2.510
Filter 6: ON PK Fc 2873 Hz Gain -8.4 dB Q 1.230
Filter 7: ON PK Fc 4598 Hz Gain 5.1 dB Q 2.620
Filter 8: ON PK Fc 7600 Hz Gain -1.7 dB Q 3.000
Filter 9: ON HSC Fc 3000 Hz Gain 5.2 dB Q 0.710
Filter 10: ON HSC Fc 10000 Hz Gain -5.2 dB Q 0.710
The measured frequency response of which can be seen below,
I would recommend decreasing the region from 2-5kHz a bit, but even so this EQ manages a predicted preference percentage of 96.57%. Lastly, it's worth mentioning that Oratory confirmed that the phase angle is around 0° when time-of-flight is subtracted.
