pspivak
- Jan 3, 2004
That rig sounds great. I've always been interested in the speaker emulation that the Phonitor can provide. Do you use the crosstalk or any other controls or just use it as an amp? And did you notice a big difference between running the headphones balanced/unbalanced? I thought the Phonitor only had a TRS output.
Hi again,
1. Yes, I do use the crosstalk control, the balance control and the meter calibration switch. The crosstalk control is interesting and does work as advertised. I read some reviews and copied one reviewers setting suggestions. Now I just leave it in that position. I do not think I am missing much in terms of soundstage width with the circuit switched in, I like it. Also, I do forget that I am listening to headphones sometimes. Some have knocked the soundstage of the LCD-XC that it is in some way constricted. I believe that compared to the LCD-X it may be a little narrower but it is not a game stopping weakness. I really like the balance control too. I have found that different studios and engineers have a differing "idea" of where the middle is. I thought it was just age.
2. The owners manual from SPL does present the ability to use the two 3-pin XLR outputs on the back to drive headphones in a balanced configuration. Ted from HPL made great cable for me to use with the XC's. At first it sounded not as good as I wanted, then one evening the sound literally made a belch (I kid you not!) and suddenly all was right. I was skeptical about break-in for electronics and cables but I am a believer now. I prefer the smoothness and liquidity of the balanced configuration by a wide margin over single ended.
3. The Hilo and the SPL mate real well. Really low noise floor, great definition, and some of the most well know studios use SPL and Lynx equipment; I think they are a good match.
The system sounds real good to me from streaming Tidal to DSD files (I have one).
Anyhow, thanks for asking.
