x RELIC x
Forget Hugo 2 plus mscaler you can’t go dual bnc and get the magic highest output.
Misinformation. Of course you can do dual BNC with the Hugo2 and get the full M scaler output, but you need an adaptor.
An adaptor!!!Misinformation. Of course you can do dual BNC with the Hugo2 and get the full M scaler output, but you need an adaptor.
An adaptor!!!
Not misinformation
who would use a adaptor this day and age?
An adaptor!!!
Not misinformation
There are alot of people that run the h2 with the mscaler. Moon audio sells a dual bnc to 3.5mm dual coax cable. I used to have this setup but found that the hugo2 was just too close to the sp1000 to keep both.
Ps Rob watts himself uses the hugo2 with mscaler as a mobile setup on planes.
Keep in mind that the LCD-2 has this 'staggered' magnet configuration too, yet it has a similar sound signature (according to FR response graphs, which match my experience comparing the LCD-2 to the LCD-4z). I don't imagine it will radically alter the sound signature.My main concern is that this produces a more linear tonal balance and less of that classic Audeze dip in the upper mids. An improved soundstage would be great too. That would make these a winner. This is the great thing about competition. Meze and ZMF are bringing it to Audeze and they have to improve their offerings or risk slumping sales.
One hundred percent on that. In that regard Audeze needs to get into the modern age. Meze and ZMF have shown that pad changes can instantly help you customize your sound. The glued on pad thing is so early 2000. There is no going back on being able to swap out your pads easily at this point.Exactly. And they still need to work on comfort, weight, and an earpad system that doesn’t use glue or adhesive! I’m sorry but it’s not that hard to adopt or invent a system that makes it easy to swap earpads. (Thank you Ultrasone and Meze).
Are you going to give the 24 a whirl?Exactly. And they still need to work on comfort, weight, and an earpad system that doesn’t use glue or adhesive! I’m sorry but it’s not that hard to adopt or invent a system that makes it easy to swap earpads. (Thank you Ultrasone and Meze).
