Audeze LCD-4
Nov 29, 2023 at 6:39 PM Post #11,716 of 12,471
Roon on Mac works great. I use it and the Reveal EQ settings included with my LCD4 and CRBN.
Please tell me you are not using those Audeze Preset EQ settings in Roon because its horrendous imo.
@planar shill I just think an LCD 4 is a perfected ZMF sound signature.
Nov 29, 2023 at 7:57 PM Post #11,718 of 12,471
I am an LCD-4 goon, and I often think people are crazy for selling them. Which ZMF models do you think sound like LCD-4?
I'm not saying they sound exactly alike but if you look at something like the Caldera they both go for the warm, lush and thick sound signature. The difference with ZMF headphones is that they have a plethora of different pads you can try which will change the sound signature depending if you like a brighter or warmer sound.
Nov 29, 2023 at 8:58 PM Post #11,720 of 12,471
I've tried the Caldera several times at shows, and I find them a little thinner than the LCD-4. I prefer the Atrium for it's richer sound. It sounds more natural to me. It's closer to the LCD-4 in fullness I think, though probably not in detail. I haven't A/B'd them.
Nov 29, 2023 at 9:36 PM Post #11,721 of 12,471
I do use the Roon EQ. I rather like them. Of course sound preference is just that, a personal preference. So your opinion is valid for you. I'll let others decide for themselves. Easy enough to try and toggle on and off.
Nov 30, 2023 at 5:13 AM Post #11,723 of 12,471
Nov 30, 2023 at 5:15 AM Post #11,724 of 12,471
Nov 30, 2023 at 5:18 AM Post #11,725 of 12,471
Nov 30, 2023 at 4:33 PM Post #11,726 of 12,471
Norne cables, not Nord! Haha.
https://www.norneaudio.com/litzheim/
Find them used, they're not going to make anything sound better. But they WILL look very cool.
I have one of these for my LCD-4 as well, got a Vygarde last year. Honestly, didn't notice a change soundwise, but the build quality is superb and the cable is incredibly flexible! Well worth the cost if you can swing it, although you could probably opt for the cheaper Drausk and get the same great build quality.
Nov 30, 2023 at 5:29 PM Post #11,727 of 12,471
Frequency response of my 4z manufactured 6 months ago -
Compared to my LCD4 -
I suspect there’s a different level of smoothing between graphs but I can happily listen to the 4z stock without any EQ whereas my LCD4 needs a lot of EQ. A single high shelf on the 4z makes it practically flat. The 4z sounds much better to my ears and doesn’t need to be driven by a nuclear reactor.
Dec 2, 2023 at 4:54 PM Post #11,730 of 12,471
Has anyone tried Chord Anni with LCD4? Can Anni provide enough power to drive them with authority?
I haven't but I doubt any portable amp would be powered sufficiently to drive an LCD 4. The LCD 4z will be fine with portable amps though for the most part.
