Kozwoz
- Nov 26, 2014
I appreciate what you’re saying about power but I disagree regarding volume. Volume is not a good indication of power output. I have low powered amps that have less than a watt of power output that can make the LCD4 go very loud even before I reach the 12 o’clock but this doesn’t mean it’s being driven properly. I generally find the LCD4 needs a few watts to really shine. I’m sure there are exceptions and would be keen to hear the HA-3A for myself.I'm actually running the LCD 4 on the HA-3A With the 1/4 Jack cable. I'm never going passed 11 o'clock on the volume dial on the highest impedence switch so it has the power trust me. I have to use more of the volume dial on the Lyr 3 which has 9 Watts of total power. The HA-3A is a beast and you will only need the HA-6A for headphones like the Susvara or HE6.
I asked the people at the HA-3A thread before I bought it to see if it had the power and someone said this:
"At this impedance levels the current output is much more important than the raw power. HA-3A has a ton of current for the LCD-4"
They were 100% right, as long as you set it to the highest impedence switch on the amp then your good even with the 1/4 jack.
