Violectric V280 or V281 can be found used in that price range and Drop.com just had a run of new V280’s at $1200. They are really dynamic amps that compliment the LCD-4 quite well and have bass slam and low-end grip to spare.Could I please have some amp only recommendations for £1k or roughly $1300. Is there anything at this price point that will work well with the LCD4? Much appreciated. I like a smooth top end with plenty of bass slam.
Audeze LCD-4
- Thread starter Matias
- Tags
- audeze-lcd-4
ThanatosVI
Up to this price there are a few amps able to drive the LCD-4 well.
Schiit Mjolnir 2 850$
Schiit Jotunheim 500$
Schiit Lyr3 600$
Monoprice THX 887 500$?
Drop and SNSL THX variants.
All those should be able to drive the LCD 4 well.
Maybe it's my limited knowledge but after that there usually is a huge price jump in the amp section. (I'm curious myself what else there is)
I drive my LCDs with the monoprice 887 ($400 actually) and I keep it at the second of three gain settings and tweak vol from there. Volume is very reasonable at this level.Up to this price there are a few amps able to drive the LCD-4 well.
Schiit Lyr3 600$
i just bought a pair of lcd-4 and was wondering about amp and dac pairing. wasn't planning on buying an expensive headphone but found a used pair online. i don't want to spend a lot more for an amp and dac. does anyone know a good setup that doesnt cost that much. i'm looking at ifi Micro iDSD Black Label, but any help would be appreciated. price range is around $1kish or less.
ThanatosVI
For 1k total I'd recommend a Schiit Jotunheim 400$ + the newly released Schiit Modius DAC 200$. That's 600$ and works fine to use them.
Obviously it doesn't make them schine to perfection, however nothing below 1k total will do that.
If you want some tube magic you can go for the Schiit Lyr3 500$ or for a higher price the Schiit Mjolnir 2 850$
Other options are e.g. the new Topping A90 amp for 500$.
Monoprice THX 887 400$
Drop or SNSL THX 789 also 400$ (drop 300$ but rarely available)
If you amp up the budget to let's say ~1200, you have a few more excellent DAC choices to pair with.
Schiit Bifrost 2 700$
Topping D90 700$
Denafrips Ares II ~750$
Personal choice here would be to bite the bullet with a slightly higher price and get a
Schiit Bifrost 2 + Schiit Jotunheim. for 1100$
Great recommendations.For 1k total I'd recommend a Schiit Jotunheim 400$ + the newly released Schiit Modius DAC 200$. That's 600$ and works fine to use them.
Topping D90 700$
oh wow. thank you. im going to go check them out.For 1k total I'd recommend a Schiit Jotunheim 400$ + the newly released Schiit Modius DAC 200$. That's 600$ and works fine to use them.
Topping D90 700$
It's all good stuff there.oh wow. thank you. im going to go check them out.
808 related to 808 State?oh wow. thank you. im going to go check them out.
yeah. hawaii . 808 area code.808 related to 808 State?
Kozwoz
- Nov 26, 2014
Any quick comparisons between the Schist JOTUNHEIM and the Monoprice THX 887 with the LCD4 as they are priced similar? Which one does bass and or mids better?For 1k total I'd recommend a Schiit Jotunheim 400$ + the newly released Schiit Modius DAC 200$. That's 600$ and works fine to use them.
Topping D90 700$
whirlwind
I have joined the club,just have to wait for them to arrive. I have a few amps to try with them and I much look forward to it. I recently just sold my LCD-3 pre razor and I hope I won’t miss them too much
by chance does anyone know a good site to buy used amp/dac?For 1k total I'd recommend a Schiit Jotunheim 400$ + the newly released Schiit Modius DAC 200$. That's 600$ and works fine to use them.
Topping D90 700$
sahmen
- Apr 6, 2014
Speaking of Amps, how about the Gustard H20, which is now on Massdrop? I've never heard it, but it seems to have what it takes to drive the 4 well.
ThanatosVI
Should work fine, however it tells me Sold out.Speaking of Amps, how about the Gustard H20, which is now on Massdrop? I've never heard it, but it seems to have what it takes to drive the 4 well.
What was the price?
Also a little confused about the power output.
The 6w in 32ohm would be like the drop thx 789
12w in 32 Ohm is insanely powerful though.
Total: 8 (members: 0, guests: 8)
