protoss
- Mar 21, 2017
Hey guys and gals got a question for you. What would you all recommend as far as another TOTL planar headphone that is different enough from the LCD-4 to justify owning it. Ive owned the Ether 2 and loved it and considered owning it again, I have also heard a ton of great things about Hifimans TOTL planar offerings and am quite intriuged by the Susvara even though Im not fond of the price tag I think if enough people tell me its worth owning in conjuction with the LCD-4 that may likely be the one but open to all recs. thanks
I think the Abyss and LCD4 will compliment each other well. I have an Abyss Phi CC and LCD3F.Hey guys and gals got a question for you. What would you all recommend as far as another TOTL planar headphone that is different enough from the LCD-4 to justify owning it. Ive owned the Ether 2 and loved it and considered owning it again, I have also heard a ton of great things about Hifimans TOTL planar offerings and am quite intriuged by the Susvara even though Im not fond of the price tag I think if enough people tell me its worth owning in conjuction with the LCD-4 that may likely be the one but open to all recs. thanks
@donato I assume you are referring to the headphone cable in your reviews. How drastic would you say the change is from a copper cable vs the two silver cables you tested? Is it a substantial and easily noticed difference or something you have to really look for? Last question how much did each of the two silver cables cost for your LCD-4's?[/USER]
