Shane D
I rarely ever play Nickleback specifically. They just come up in my playlists. I probably have more than 20 of their songs, but rarely go on a Nickleback tear.Did you try already with Nickelback??
Look I'm sorry, but if you can't listen to the LCD2C without EQ then you've bought the wrong headphone for your ears and personal preference. It's great that you can make up the perceived shortcomings you experience with EQ and have a good experience with it.So basically you are saying that instead of enjoying "the best sound to my ears ever", thanks to PEQ (i.e. PEQ LCD2C vs stock LCD2C, which I can't listen to without PEQ vs stock HD650), I should instead settle for something that I enjoy less (HD650), only to favor not having to use PEQ, even when I have no problem integrating PEQ into my system?
Logic? Please explain. And, no, spending $3k, $5k, $10k on a headphone doesn't solve this equation, since you can have the same problem at any price point.
Just keep in mind that I'm not saying the LCD2C is worth buying over any and all other headphones in its price range. I still find it a broken headphone without PEQ. It's just an example how fixing a headphone tonality can reveal it's true potential, even make it the best, the true endgame.
As I said, if it's unlistenable flat, walk away and find something else. I can listen to all of my headphones flat and appreciate the tonality differences between them and what they bring to the listening experience. EQ is really only for minor adjustments to account for an unfavourable mastering or mixing, and even then + or - 3db is the max you should really be looking at.
If you've found your nivana through EQ that's great. However I don't want people here buying headphones because everybody has said they're great and then find that they sound crap without EQ - and unfortunately it appears from this forum that most people have no idea what EQ is, and even less know how to apply it.
I gave you a perfect real practical example why what you are proposing as some kind of philosophy against EQ doesn't make any sense. You refuse to back up your anti EQ philosophy with a practical example, I don't really care, I'm perfectly fine and used to folks' random nonsense.
I don't have anything against EQ at all - I use it all the time in production. I'm just saying that if you buy headphones or speakers (speakers get a joker card here for room correction) and you have to EQ the crap out of them to make them sound good to your ears then it wasn't the right purchase.I gave you a perfect real practical example why what you are proposing as some kind of philosophy against EQ doesn't make any sense. You refuse to back up your anti EQ philosophy with a practical example, I don't really care, I'm perfectly fine and used to folks' random nonsense.
Possible to show us pics, mate? Seems like it is a positive revision. Pretty sure there should be positive change in sound as well.Just got in what I believe is the newest 2021 batch LCD-2 classic from Audio46. Changes from the 2018 version that I have had and sold:
1) head strap seems to be real leather now, identical to LCD-X. So thicker and less prone to stretching comparing with the previous thin synthetic strap
2) earpads are non-memory foam. They are plusher and slightly thinner than the previous memory foam pads. More comfy for me
3) metal mesh underneath the metal grill. This is a well-known revision that happened before this year
4) quarter inch jack is changed to a newer style and do not have the big Audeze logo.
I do not find the sound to change noticeably, at least without direct AB.
Here are some pics of these cans:Possible to show us pics, mate? Seems like it is a positive revision. Pretty sure there should be positive change in sound as well.
So the headband is thicker and more durable now, and the Pads thunder.Here are some pics of these cans:
new style jack:
Here is the 2018 version with memory foam pads:
You can see the pads are thinner now. I sold my old pair to upgrade to the newest LCD-X but found my ears touching the fazors. So I have to switch back to the good-old LCD-2 classic, which still rocks
I much prefer the newer pads, because they have more give. Also, due to the reduction in thickness the clamp force is less. Downside is that ears will be more likely to touch fazors on fazored models.So the headband is thicker and more durable now, and the Pads thunder.
I had the 2018 Version as well, really liked the Pad comfort.
Do you have both at the same time so that you can compare if the sound changes?
Hopefully they still sound as good as the 2018 version
