capone
Aka: johnwmclean, bignurse.
- Oct 12, 2011
I have a problem with with my Beta22 balanced amp. The attenuator a khozmo quad, has static and clicking noises when turning the volume, once the volume is stationery they is no noise.
It it most evident and mainly in two positions at the lower setting of the volume, steps 6-7 from memory. It’s not a hum noise, I’m pretty sure it’s not a ground connection.
When no input is connected to the amp and I turn the volume up there is no noise whatsoever. I’ve checked the dc-offset of my buffalo32 and it’s in the 0.5mv range from the balanced outputs.
I’m thinking it’s the Khozmo...
