ATH-SJ11 or ATH-SJ33 or ATH-SJ55
May 3, 2011 at 9:02 PM Post #17 of 41
I didn't say that it was bad, but it doesn't excel in portability like the SJ11 or in sound like the SJ55. I would recommend it if the SJ55 was out of the person's price range and didn't mind a slightly less portable can. They sound good, but the SJ55 sounds better and looks the same. For my money I'd rather put it in a better can, and they don't even cost that much more than the SJ33s either. The biggest difference (for me) is in the highs, which seem so much more crisp on the SJ55s when compared to the SJ33s. None of the three have really fantastic bass. That is not to say the bass is bad. It is nice and punchy, and sounds good enough, but lacks the power I am used to from other cans.
Is the Sj33 that bad? I was thinking of buying them, they look good to me...
May 4, 2011 at 3:10 PM Post #18 of 41
Well i usually listen to classic or rock music... So from what you are saying the SJ55 are more along the line of those genres no? Or can the SJ33 also be good at these types of music? Sry for asking too much, but i'm kind of a newbie :).
May 4, 2011 at 9:38 PM Post #19 of 41
I'd say yes, because the highs are more crisp and clean. On 33s you can hear some distortion in the higher notes, that the 55s don't have. It bothers me personally, but I'm not sure about you. Perhaps you won't even hear the same things I did. Everyone hears differently. I'd always recommend the 55s over the 33s, and the 11s if you want portability. Again, if the 55s are out of your price range, the 33s will perform admirably, and will be almost as good for those genres. The highs may leave something to be desired, but again that is only from my experience.
May 5, 2011 at 6:20 AM Post #21 of 41
anyone compared the SJ55 to the AKG K81/518 DJ/LE ? Would be an interesting comparison i think.
May 5, 2011 at 12:20 PM Post #22 of 41
May 5, 2011 at 1:41 PM Post #23 of 41
thanks, it's very breif, if some one could do a more in depth one it would be good.
May 11, 2011 at 11:47 PM Post #25 of 41
Jun 4, 2011 at 11:26 AM Post #28 of 41
Glad you are enjoying them. I'm a big fan of them. I'd buy them if I needed a sub $100 pair of cans for portable, but for now my HJE900s and TMA-1s are doing nicely for my purposes.
Finally bought a pair of SJ55s. They are surprisingly rather good. Better than any ~50-60 dollar cans I've ever owned or heard (K 81, PX100-I, PX-200-I)
Jun 4, 2011 at 7:44 PM Post #30 of 41
For those buying these, the SJ1 and SJ3 sound way inferior to the SJ5, which would probably be true for the 11 33 and 55 as well
Yes, that is indeed the case, but the SJ11 is a bit more portable than the SJ33 and SJ55. Also, if you are familiar with those models, just assume that they greatly improved on those original models. Because they did. I have heard both and the 11,33, and 55 are all superior to their older counterparts.
