dddavidp
- Jul 9, 2014
No problem brah.
For the K612, be prepared to drop another 100$ on an amp... But then you get a mid-fi open back that bests all the above for neutrality and detail if you do so. Not good at all for traveling just because it is open back with no isolation. The AD900X is a logical upgrade if you plan on staying with audio technica by the way... Or AD700X and AD500X even. Very mid-rangey however. Not very fun headphones tbh. For a closed back around 200$, the DT770 is great, but not neutral. Very warm and bassy. For an closed neutral headphone around 200$, the AKG K550 comes to mind. If you want a portable on ear, then I suggest Thinksound on1... Imo, the best closed back for its price period. It isn't neutral, however it is just fantastic.Hey guys,
I got some white M50s 2 years ago (not to mention the obvious with the color), replaced the earpads a year ago. Unfortunately I got so used to the sound of them, that I was wearing them everywhere and under all conditions. Now they are starting to fall apart again.
They were my first "high quality" headphones by then, but now I think it's time for a change and maybe upgrade sound and quality.
Do you think I should stay with Audio-Technica M40X/M50X or change to another manufacturer?
I was looking on different sites for some weeks now and I'm not getting closer making a decision between M40X (price), M50X (habit), Beyerdynamic DT770/32ohm (more for the studio), AKG K612Pro.
ah, and I use them mostly for listening on my way anywhere, including a little analysis sometimes, late night mixings in my homestudio, and field recordings. (basically everywhere)
Can anyone convince me for ONE of these?
(I know it's a ATH-MXX Thread, but I thought I could maybe get some new opinions...
Hey guys,
One headphone for everywhere among those? ATH-M50x, though it is only a very slight upgrade from regular M50. I think that the original pads suck majorly, replace them with Sennheiser HD280 pads instead, they give the bass all the clarity and control that they normally lack, and bring out the best in the midrange and the treble (silkier treble on M50x). The pads de-color the sound to a degree, too, and since they are a little deeper and bigger than the original pads, I guess that the drivers just needed to breathe a little more. They are not the most comfortable earpads ever, so if you end up loving the change, which I'm sure you will, but find them uncomfortable then try the memory foam HM5 earpads instead. M50 will sound nearly as good with those pads as with the HD280 pads.
x2 on K612 if them being huge and open doesn't bother you, and they may need an additional headphone amplifier if your studio equipment cannot bring out the best in them, although I imagine that is unlikely.
I don't really consider buying the K612 any more, just a thougth if I could raise the money for two pairs. I built myself a portable battery powered amp for low power mobile devices which drive the 68 Ohms of the M50 without any problems and even expand the frequency range.
Since its getting a little colder here, I'm wearing them over my cap and I first thought a bass-boost was activated somewhere on my phone.
So a little distance to the drivers enhances the low end noticeable. Thanks for this! Do all those pads mentioned fit on the M50X?
Would you recommend the normal or the velour version of the thick HM5 earpads?
Hey Lauzy,
I haven't tried the M50X's but I would stick to the M50's as they are a proven entity.
The M50X's have a detachable cable but soundwise I would have to try them to find out.
By the way never buy headphones with an in-line volume control if you want the best sound possible as the signal is diminished significantly due to the extra control in the signal path.
I personally would also prefer a wired cable instead of a detached plug in cable as it is fixed by soldering not a possibly temperamental 3.5mm jack plug.
If you can get to try before you buy that would be the best option, but if not M50's everytime!
Good listening!
Thanks for the feedback, I am pleased to know I've helped someone make a wise choice with their money.
By the way my belief is that anything that disrupts the signal path from source to output can only detract from sound quality.
Manufacturers only add these extra things to appeal to a wider audience in an attempt to make more money without telling us about the deterioration in sound quality that they cause.
They are all a gimmick and a marketing ploy.
It's like selling a jar of the finest pure honey in the world adding a pound of sugar to it, then selling it to the customer as an improvement on the original product, a total con.
I'm happy I helped, stay smart,
Good listening!
