Comfy
- Mar 15, 2005
Thanks for the reply and the pic. Would this solution be sonically ideal? Or would that stepdown transformer noticeably reduce the quality? Are that kind of transformers expensive?
And most importantly, would it be worth the hassle to go from MPX3 SLAM to a stepdown transformer fitted HA5000?
Thank you for your comments. I'm seriously considering this step.
Originally Posted by Elephas You can use a 220V to 100V stepdown transformer. Also some power regenerators and conditioners can be set to 100V output. |
