Sunkinator
- Dec 30, 2006
because no one has an es7 and an rp-21, other aspects of the headphones should be compared.
rp-21
Cons:
The rp-21 is big (circum-aural) which makes it less than ideal for portable use.
The rp-21 has an bronze paint job which could look horrendous in public (nobody has a picture of it on their head)
The parts are manufactured in China/Taiwan and (no offense) but history shows that china and taiwan are not countries that usually make high quality parts.
Pros:
The rp-21 is said to have very good sound quality (some people rave that it's sound quality rivals headphones 3x it's price)
The rp-21 is probably more comfortable because it rests over your ears, not on them.
By being made in China/Taiwan, they can make better transducers for lower amounts of money (and those savings get passed on to the consumer)
Isolation is OK
es7
Cons:
They are Supra-aural which can cause comfort issues
Their mirror finish easily accumulates fingerprints/dust/scratches which limits their portability as well.
They do not look very sturdy
Isolation is less than rp-21
Pros:
They have good bass/midrange and their highs are not shrill.
They look good with the mirror finish earcups
You can get them for less than half their msrp (I dont know if that counts as a pro)
__________________________________________________ _______________
Now that I look at them, they both seem undesirable for portable use.
Someone should compare the rp-15mc to the k-81dj because everybody who wants an es7 really just wants a better headphone than a k-81.
If the rp-15 is better, it will satisfy your sound quality needs at half the price of the rp-21/es7 and $20 less than a k-81. With the extra 50 bux, you could save up for an amp or something better than the es7. (just a thought)
rp-21
Cons:
Pros:
Isolation is OK
es7
Cons:
Pros:
