Asus mainboard SPDIF output quality
Mar 12, 2009 at 2:15 PM Post #5 of 27
I used the SPDIF coaxial output on my P5Q3 Deluxe for a time until I got my USB transport.
I use Windows XP 64 bit, which doesn't have the newer Vista/7 audio kernal and so I was locked to using 48khz output rate from the motherboard, I believe that this resampling issue was in large part the reason for the difference in sound between the transports (I had to slightly reposition my speakers after the change), but the proximity to all that noise in the PC and a power supply not built to be audio grade will also have been factors.
The sound wasn't bad by any means, but if you've got a decent DAC, you really should get at least a half decent transport for it. The Trends Audio UD10.1 Lite does such a job for me.
Mar 12, 2009 at 11:18 PM Post #9 of 27
Originally Posted by FallenAngel /img/forum/go_quote.gif
Personally, I think the EMU 0404 PCI is the best bang/buck transport as it's not expensive ($50 or so), has nice software (yes, I actually do like it) and offers bit-perfect, transformer-coupled coax S/PDIF output.
X2
unless you need multi-channel, the 0404 is a great route, and I had no idea it's gotten down to ~$50 (thats crazy.)
Mar 13, 2009 at 5:17 AM Post #10 of 27
The audio chip on that board is a RealTek so it is actually pretty good for onboard sound. Not on par with a good external card solution, but you can get by with it. SoundMax is the onboard stuff you want to avoid.
Mar 13, 2009 at 5:22 AM Post #11 of 27
Don't expect it to be bit-perfect, well timed or transformer coupled. In other words, get a proper transport.
^^ if you didn't read FA's point, you should
and why do you have to be external? theres nothing to be gained from external over internal, either is really quite fine
Mar 13, 2009 at 8:26 AM Post #14 of 27
My motherboard has a Realtek ALC889A which IS bitperfect. I guess the ALC1200 on your board is even better at some fields, but it's not even mentioned on the Realtek site.
Mar 13, 2009 at 10:06 AM Post #15 of 27
Originally Posted by #@y0 /img/forum/go_quote.gif
I have an ASUS mainboard with SPDIF output and I was wondering if anybody knows something about the quality of the SPDIF out.
Its bitperfect,I use it playing DVD's to feed a AVR.
